- To:
- Subject: Re: [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction
- Date: Thu, 25 Aug 2011 15:27:05 +0200
Hi Marc,
1) Which version of CGAL do you use? My understanding is that you use VC++ 8
2005 which is not supported by recent CGAL versions.
2) What results do you get with
surface_reconstruction_points_3/poisson_reconstruction_example.cpp out of the
box, just compiled on your machine (prepare the point set with the Qt demo)?
Best regards,
Laurent Saboret
Le 25/08/2011 11:17, Marc Klopfenstein a écrit :
Hi,
I made some more test with the demo. The demo works for the Bimba point set
and for my own point set. I found the problem mentioned in my last post when
using my own point set and the demo. I had a normal problem in the point
set, I switched from my mormal calculation method to a CGAL normal
calculation method.
So to sum up,with the demo I run the Poisson reconstruction with max. 550
000 points. With my code, can run Poisson reconstruction with max. 250 000
points. As mentionned in a previous post, I probably have a compilation
issue. Do you have an idea about this problem or a clue where to start
looking.
Best regards,
Marc
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-Poisson-Surface-Reconstruction-tp3616368p3767755.html
- Re: [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, (continued)
- Re: [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Laurent Saboret, 08/03/2011
- [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Marc Klopfenstein, 08/08/2011
- [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Laurent Saboret, 08/09/2011
- [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Marc Klopfenstein, 08/09/2011
- Re: [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Laurent Saboret, 08/09/2011
- [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Marc Klopfenstein, 08/10/2011
- Re: [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Laurent Saboret, 08/11/2011
- [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Marc Klopfenstein, 08/11/2011
- [cgal-discuss] out of office, Marc Klopfenstein, 08/11/2011
- [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Marc Klopfenstein, 08/25/2011
- Re: [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Laurent Saboret, 08/25/2011
