- To:
- Subject: [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction
- Date: Tue, 9 Aug 2011 04:14:17 -0700 (PDT)
Hi Laurent,
*My configuration:*
Windows XP SP3
Visual Studio 8 C++ 2005
3 Go RAM
2046Mo virtual memory
I use the latest version of Taucs.
*Do you get the same error in Debug and Release mode?*
NO, in release mode I have an another Taucs problem (see log).
CONSOL OUTPUT
Number of point: 465251 (own cout)
Creates Poisson triangulation…
Creates Poisson triangulation: 9.844 seconds, 175Mb allocates
Delaunay refinement…
Calls
Delaunay_refinement(radius_edge_ratio_bound=2.500000,cell_radius_bound=0.119956,
max_vertices= 10000000, enlarge_ration= 1.500000)
Calls poisson_refine_triangulation()
176Mb allocated
Creates queue
Max allocation in Delaunay refinement = 387Mb
233Mb allocated
End of poisson_refine_triangulation()
End of Delaunay_refinement()
Delaunay refinement: added 258327 Steiner points, 197.889 seconds, 233 Mb
allocated
Solve Poisson equation with normalized divergence…
Calls solve_poisson()
233 Mb allocated
Creates matrix…
Creates matrix: done (119.55)
359Mb allocated
Solve sparse linear system…
Error: cannot solve Poisson equation
TAUCS LOG
taucs_linsolve: preparing to factor
taucs_linsolve: ordering (llt=1, lu=0, ordering=metis)
taucs_linsolve: ordering time 9.61e+000 seconds (9.55e+000 seconds CPU time)
taucs_linsolve: starting LLT factorization
taucs_linsolve: pre-factorization permuting of A
taucs_linsolve: starting IC LLT factorization
taucs_linsolve: starting IC LLT MF factorization
Elimination tree depth is 6836
Symbolic Analysis of LL^T: 1.57e+008 nonzeros, 2.11e+011
flops, 1.42e+009
bytes in L
Relaxed Analysis of LL^T: 1.73e+008 nonzeros, 2.16e+011
flops, 1.61e+009
bytes in L
Symbolic Analysis = 5.781 seconds (5.766 cpu)
Supernodal Multifrontal LL^T = 70.875 seconds (70.719 cpu)
taucs_factor: factorization failed
taucs_linsolve: an error occured, releasing resources and bailing out
Solving Failed
Do you get the same error with other point sets?*
Yes we have the same error with other point sets. The reconstruction works
with less then 250 000 points, above this limitation I have the same problem
and the same differences between Release and Debug
Best regards,
Marc Klopfenstein
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-Poisson-Surface-Reconstruction-tp3616368p3729644.html
- Re: [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Laurent Saboret, 08/01/2011
- [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Marc Klopfenstein, 08/02/2011
- Re: [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Laurent Saboret, 08/03/2011
- [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Marc Klopfenstein, 08/08/2011
- <Possible follow-up(s)>
- [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Laurent Saboret, 08/09/2011
- [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Marc Klopfenstein, 08/09/2011
- Re: [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Laurent Saboret, 08/09/2011
- [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Marc Klopfenstein, 08/10/2011
- Re: [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Laurent Saboret, 08/11/2011
- [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Marc Klopfenstein, 08/11/2011
- [cgal-discuss] out of office, Marc Klopfenstein, 08/11/2011
- [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Marc Klopfenstein, 08/25/2011
- Re: [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Laurent Saboret, 08/25/2011
