- To:
- Subject: Re: [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction
- Date: Thu, 11 Aug 2011 09:29:25 +0200
Hi Marc,
You may try the Surface Reconstruction demo pre-compiled for Windows:
This demo allows you do load point sets and run the Poisson Surface
Reconstruction algorithm. You can also decimate point sets or compute normals.
Go to http://www.cgal.org/Manual/latest/doc_html/cgal_manual/packages.html. Download
and unzip the "Demo: Surface Reconstruction" link.
You will need Qt 4. Qt 4 is free on Windows if you compile it by yourself.
If the demo works on your machine, you probably have a compilation issue.
Best regards,
Laurent Saboret
Le 10/08/2011 11:31, Marc Klopfenstein a écrit :
No changes after increasing my virtual memory.
Other ideas?
Best regards,
Marc Klopfenstein
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-Poisson-Surface-Reconstruction-tp3616368p3732407.html
- Re: [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Laurent Saboret, 08/01/2011
- [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Marc Klopfenstein, 08/02/2011
- Re: [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Laurent Saboret, 08/03/2011
- [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Marc Klopfenstein, 08/08/2011
- <Possible follow-up(s)>
- [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Laurent Saboret, 08/09/2011
- [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Marc Klopfenstein, 08/09/2011
- Re: [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Laurent Saboret, 08/09/2011
- [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Marc Klopfenstein, 08/10/2011
- Re: [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Laurent Saboret, 08/11/2011
- [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Marc Klopfenstein, 08/11/2011
- [cgal-discuss] out of office, Marc Klopfenstein, 08/11/2011
- [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Marc Klopfenstein, 08/25/2011
- Re: [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction, Laurent Saboret, 08/25/2011
