cgal-discuss - Re: [cgal-discuss] license of CGAL's Tet mesh generation... compatible with Slicer license?
  • To:
  • Subject: Re: [cgal-discuss] license of CGAL's Tet mesh generation... compatible with Slicer license?
  • Date: Wed, 14 Sep 2011 16:03:53 +0200
On 14/09/2011 15:58, Audette, Michel A. wrote:
Hi Andreas,
this is the answer that I wanted. Thanks for your kind reply.
So to summarize and extend a little further the discussion:
i) The BSD license of Slicer is compatible with the QPL license of
Slicer, as long as no commercial application is built on the two
together.
correct.
ii) If it were the case that a product would be built on
the two technologies, the company producing it would have to
negotiate a commercial license with you, correct?
correct.
iii) These
licensing issues are not circumvented by simply producing plugins
based on CGAL.
correct. I guess you still could circumvent by the plugin
being a separate executable and pass data through files,
but to be sure ask a license expert, not us.
iv) These licensing issues do not restrict the
commercialization of anatomical models produced by a combination of
Slicer and CGAL, as opposed to an application built on the two,
correct?
correct
andreas
Best wishes,
Michel
Michel Audette, Ph.D. Assistant Professor, Department of Modeling,
Simulation and Visualization Engineering, Old Dominion University,
Norfolk, VA. ________________________________________ From: Andreas
Fabri
Sent: Wednesday, September
14, 2011 9:50 AM To:
Subject: Re:
On 14/09/2011 15:38, Audette, Michel A. wrote:
Dear CGAL developers, my collaborators and I are giving some
thought to integrating the CGAL tetrahedral mesh generation with
Slicer, but I was wondering about the particular license of this
implementation: can the license be made compatible with Slicer's,
which is BSD? Can any restriction be circumvented by distributing
binaries only? Best wishes, Michel Michel Audette, Ph.D. Assistant
Professor, Department of Modeling, Simulation and Visualization
Engineering, Old Dominion University, Norfolk, VA.
Hi Michel,
CGAL is under the QPL, which is compatible with BSD. Only
distributing binaries is not a solution but a problem: The QPL
obliges you to distribute source code.
Note that as slicer is distributed under BSD it can be integrated in
commercial code. By integrating CGAL in slicer, this is no longer
possible, as users have to take into account the strongest
restriction of the licenses. That is, when you integrate CGAL, the
CGAL files of the slicer distribution are still under the QPL and not
under the BSD.
Hope this helps,
andreas -- Andreas Fabri, PhD Chief Officer, GeometryFactory Editor,
The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
-- You are currently subscribed to cgal-discuss. To unsubscribe or
access the archives, go to
-- BEGIN-ANTISPAM-VOTING-LINKS
Teach CanIt if this mail (ID 552411580) is spam: Spam:
https://www.spamtrap.odu.edu/b.php?i=552411580&m=482e9b43d05d&t=20110914&c=s
Not spam: https://www.spamtrap.odu.edu/b.php?i=552411580&m=482e9b43d05d&t=20110914&c=n
Forget vote:
https://www.spamtrap.odu.edu/b.php?i=552411580&m=482e9b43d05d&t=20110914&c=f
END-ANTISPAM-VOTING-LINKS
Andreas Fabri, PhD
Editor, The CGAL Project
