cgal-discuss - [cgal-discuss] linear_least_squares_fitting_3() gives bad fitting quality for input of only 3 points
  • To: "群_cgal-discuss" <>
  • Subject: [cgal-discuss] linear_least_squares_fitting_3() gives bad fitting quality for input of only 3 points
  • Date: Wed, 21 Sep 2011 14:13:02 +0800
Hi all,
I am using CGAL::linear_least_squares_fitting_3() to fit planes from point
set. It works pretty well for data set with more than 3 points. But I was
surprised that this function behaved when fitting a plane form 3 points. The
function returned 0.495031, which meant the variance orthogonally to the
fitting plane was quite big. Acutally 1.0 is expected because 3 points are
exactlly in the same plane. Can someone explain?
Here is the code I call the fitting function:
Plane3f plane;
double q = CGAL::linear_least_squares_fitting_3(
pts.begin(),
pts.end(),
plane,
CGAL::Dimension_tag<0>()
And the input(only 3 points):
86.1817 3075.31 1031.53
164.575 3075.31 913.936
754.546 0 28.9401
Leon
http://web.siat.ac.cn/~liangliang/
