cgal-discuss - Re: [cgal-discuss] linear_least_squares_fitting_3() gives bad fitting quality for input of only 3 points
  • To:
  • Subject: Re: [cgal-discuss] linear_least_squares_fitting_3() gives bad fitting quality for input of only 3 points
  • Date: Fri, 23 Sep 2011 10:04:35 +0200
  • Organization: INRIA Sophia Antipolis - Mediterranee
dear Leon,
thank you for discussing this bug.
I think the problem comes from the eigenvalue computation.
we will dig this out.
in the meantime I invite you to replace the code which computes the
eigenvalues/vectors by
calls to the eigen library, and report whay you get here in this list.
thank you,
Pierre
Le 21/09/2011 08:13, Leon Nan a écrit :
> Hi all,
> I am using CGAL::linear_least_squares_fitting_3() to fit planes from point
> set. It works pretty well for data set with more than 3 points. But I was
> surprised that this function behaved when fitting a plane form 3 points.
> The function returned 0.495031, which meant the variance orthogonally to
> the fitting plane was quite big. Acutally 1.0 is expected because 3 points
> are exactlly in the same plane. Can someone explain?
> Here is the code I call the fitting function:
> Plane3f plane;
> double q = CGAL::linear_least_squares_fitting_3(
> pts.begin(),
> pts.end(),
> plane,
> CGAL::Dimension_tag<0>()
> And the input(only 3 points):
> 86.1817 3075.31 1031.53
> 164.575 3075.31 913.936
> 754.546 0 28.9401
> Leon
> http://web.siat.ac.cn/~liangliang/
