cgal-discuss - Re: [cgal-discuss] linear_least_squares_fitting_3() gives bad fitting quality for input of only 3 points
  • To:
  • Subject: Re: [cgal-discuss] linear_least_squares_fitting_3() gives bad fitting quality for input of only 3 points
  • Date: Mon, 26 Sep 2011 13:26:06 +0800
Thank you Gael for pointing out the reason.
The fitting quality was improved a lot for those 3 points (from 0.495031 to 1.0000011) by setting the EPSILON in eigen.h to std::numeric_limits<FT>::epsilon().
So... Pierre, this is not a bug, just a parameter issue. Perhaps making the "EPSILON" a parameter in the function will be more convienent for users.
Thank you again!
Leon
http://web.siat.ac.cn/~liangliang/
2011/9/25 Gael Guennebaud <>
This is because the default tolerance value in eigen.h is much too
high. Setting it to:
static const FT EPSILON = std::numeric_limits<FT>::epsilon();
fix the issue.
gael
2011/9/23 Pierre Alliez <>:
> dear Leon,
> thank you for discussing this bug.
> I think the problem comes from the eigenvalue computation.
> we will dig this out.
> in the meantime I invite you to replace the code which computes the
> eigenvalues/vectors by
> calls to the eigen library, and report whay you get here in this list.
> thank you,
> Pierre
> Le 21/09/2011 08:13, Leon Nan a écrit :
>> Hi all,
>> I am using CGAL::linear_least_squares_fitting_3() to fit planes from point set. It works pretty well for data set with more than 3 points. But I was surprised that this function behaved when fitting a plane form 3 points. The function returned 0.495031, which meant the variance orthogonally to the fitting plane was quite big. Acutally 1.0 is expected because 3 points are exactlly in the same plane. Can someone explain?
>> Here is the code I call the fitting function:
>>                 Plane3f plane;
>>               double q = CGAL::linear_least_squares_fitting_3(
>>                       pts.begin(),
>>                       pts.end(),
>>                       plane,
>>                       CGAL::Dimension_tag<0>()
>> And the input(only 3 points):
>>               86.1817 3075.31 1031.53
>>               164.575 3075.31 913.936
>>               754.546 0 28.9401
>> Leon
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
