- To:
- Subject: Re: [cgal-discuss] Volunteers for upcoming projects
- Date: Fri, 28 Oct 2011 15:12:11 +0330 (IRST)
- Importance: Normal
hi
I slove visibilty polygon of a point inside a polygon.
what can I help you?
>> I appreciate that. did you (winnie.hellmann) implement this project:
>> "calculating visibility polygon of a point inside a polygon"?
> I am not sure about what kind of project you are talking. But the
> implementation I am currently working on solves the problem of
> calculating visibility polygons for points inside a polygon. Actually it
> is even less restrictive and can calculate visibility polygons of points
> in any arrangement without isolated vertices (not only polygons and
> query points do not have to lie inside).
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
> This message has been scanned for viruses and
> dangerous content by MailScanner, and is
> believed to be clean.
- [cgal-discuss] Volunteers for upcoming projects, vivek mahajan, 10/15/2011
- Re: [cgal-discuss] Volunteers for upcoming projects, Andreas Fabri, 10/20/2011
- <Possible follow-up(s)>
- Re: [cgal-discuss] Volunteers for upcoming projects, sara Samadi, 10/17/2011
- Re: [cgal-discuss] Volunteers for upcoming projects, Winnie Hellmann, 10/18/2011
- Re: [cgal-discuss] Volunteers for upcoming projects, sara Samadi, 10/22/2011
- Re: [cgal-discuss] Volunteers for upcoming projects, Winnie Hellmann, 10/28/2011
- Re: [cgal-discuss] Volunteers for upcoming projects, zeinab hasani, 10/28/2011
