- To:
- Cc: Andreas Fabri <>
- Subject: Re: [cgal-discuss] Insertion in Constrained_Delaunay_triangulation_2
- Date: Fri, 28 Oct 2011 22:24:20 +0200
The easy answer is that you should only use functions thatOk, but actually it is documented ;-)
are documented
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2_ref/Class_Triangulation_2.html#Function_Vertex_handle_insert_in_edge6const_Point__p+_Face_handle_f+_int_i9;
... not very well though since out of that documentation I don't get the difference.
- [cgal-discuss] Vertex_handle in Vertex-Info, Winnie Hellmann, 10/28/2011
- Re: [cgal-discuss] Vertex_handle in Vertex-Info, Andreas Fabri, 10/28/2011
- Re: [cgal-discuss] Vertex_handle in Vertex-Info, Winnie Hellmann, 10/28/2011
- [cgal-discuss] Insertion in Constrained_Delaunay_triangulation_2, Winnie Hellmann, 10/28/2011
- Re: [cgal-discuss] Insertion in Constrained_Delaunay_triangulation_2, Andreas Fabri, 10/28/2011
- Re: [cgal-discuss] Insertion in Constrained_Delaunay_triangulation_2, Winnie Hellmann, 10/28/2011
- Re: [cgal-discuss] Insertion in Constrained_Delaunay_triangulation_2, Sylvain Pion, 10/28/2011
