- To:
- Subject: [cgal-discuss] Insertion in Constrained_Delaunay_triangulation_2
- Date: Fri, 28 Oct 2011 22:00:32 +0200
Hi again,
I just stumbled over inserting a point which lies on the edge of a constrained Delaunay triangulation. I tried to use insert_in_edge(point, face, edge), but checking is_valid() of the triangulation afterwards fails an assertion in the following lines:
result = result && !is_flipable(fit,i, false);
CGAL_triangulation_assertion( result );
(inside Constrained_Delaunay_triangulation_2.h)
Interestingly the following call with same point, same face and same edge index (and lt = EDGE) works:
insert(point, lt, face, edge);
I will now use the latter one, but just out of curiosity: What is the difference between those two calls? I am running CGAL 3.9.
Winnie Hellmann
- [cgal-discuss] Vertex_handle in Vertex-Info, Winnie Hellmann, 10/28/2011
- Re: [cgal-discuss] Vertex_handle in Vertex-Info, Andreas Fabri, 10/28/2011
- Re: [cgal-discuss] Vertex_handle in Vertex-Info, Winnie Hellmann, 10/28/2011
- [cgal-discuss] Insertion in Constrained_Delaunay_triangulation_2, Winnie Hellmann, 10/28/2011
- Re: [cgal-discuss] Insertion in Constrained_Delaunay_triangulation_2, Andreas Fabri, 10/28/2011
- Re: [cgal-discuss] Insertion in Constrained_Delaunay_triangulation_2, Winnie Hellmann, 10/28/2011
- Re: [cgal-discuss] Insertion in Constrained_Delaunay_triangulation_2, Sylvain Pion, 10/28/2011
