- To:
- Subject: Re: [cgal-discuss] Insertion in Constrained_Delaunay_triangulation_2
- Date: Fri, 28 Oct 2011 14:58:15 -0700
2011/10/28 Andreas Fabri
> On 28/10/2011 22:24, Winnie Hellmann wrote:
>>> The easy answer is that you should only use functions that
>>> are documented
>> Ok, but actually it is documented ;-)
> You are right. The constrained triangulation class should
> probably overload functions from base classes that make it
> invalid, or derive privately and overload what can safely
> be reexposed.
What a nice way to say that it should not derive :)
>> http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2_ref/Class_Triangulation_2.html#Function_Vertex_handle_insert_in_edge6const_Point__p+_Face_handle_f+_int_i9;
>> ... not very well though since out of that documentation I don't get the
>> difference.
> Well, only use modifying functions that are documented
> in the ref manual page of the class itself, and no inherited
> modifying functions. (Let's hope you don't find a counter
> example for this (adhoc) golden rule.
> andreas
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
Sylvain
- [cgal-discuss] Vertex_handle in Vertex-Info, Winnie Hellmann, 10/28/2011
- Re: [cgal-discuss] Vertex_handle in Vertex-Info, Andreas Fabri, 10/28/2011
- Re: [cgal-discuss] Vertex_handle in Vertex-Info, Winnie Hellmann, 10/28/2011
- [cgal-discuss] Insertion in Constrained_Delaunay_triangulation_2, Winnie Hellmann, 10/28/2011
- Re: [cgal-discuss] Insertion in Constrained_Delaunay_triangulation_2, Andreas Fabri, 10/28/2011
- Re: [cgal-discuss] Insertion in Constrained_Delaunay_triangulation_2, Winnie Hellmann, 10/28/2011
- Re: [cgal-discuss] Insertion in Constrained_Delaunay_triangulation_2, Sylvain Pion, 10/28/2011
