cgal-discuss - Re: [cgal-discuss] Help getting triangles coordinates from Delaunay Triangulation
  • To:
  • Subject: Re: [cgal-discuss] Help getting triangles coordinates from Delaunay Triangulation
  • Date: Mon, 31 Oct 2011 11:14:44 +0100
As documented here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/TriangulationDS_3_ref/Concept_TriangulationDataStructure_3.html a Facet is a pair (Cell_handle,int). The integer indicate the index of the cell opposite to the facet. So getting access to the points of the facet can be done like this: it->first->vertex( (it->second+k)%4 )->point() with k=1->3.
Note that if you are interested in a triangulation of a sphere (i.e. a surface triangulation), you need to consider only facets incident to an infinite cell.
Also, using the convex-hull solves this problem, see this example
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Convex_hull_3/Chapter_main.html#Subsection_16.2.3.
Sebastien.
horstmann wrote:
Hi there, I'm new with CGAL, i'm sure my question is very simple.
I am trying to use CGAL to do some Delaunay triangulation. I have a grid
with N 3D points over a sphere and I want to triangulate the sphere using
those points as the vertex of the triangles. I just need to get a list of
the vertex of the resulting triangles like that:
id_triangle1 vertex_1 vertex_2 vertex_3 id_triangle2 vertex_1 vertex_2 vertex_3 .......
I have done that to perform the triangulation:
std::vector<Point> P; for(i=0;i<NSPOINTS;i++) P.push_back(Point(GRID[i].x,GRID[i].y,GRID[i].z));
// building Delaunay triangulation. Delaunay dt(P.begin(), P.end());
The problem I have is that I have no idea how to get the resulting
triangulation. I figured out how to get the face_iterator, but I don't know
what to do from there:
Delaunay::Finite_faces_iterator it; for (it = dt.finite_faces_begin(); it != dt.finite_faces_end();
it++){ std::cout << dt.triangle(it) << std::endl; }
I'm not sure if that is correct to iterate over the triangles, and if it
is... a triangle = face ??¿ , i mean , each iterator position have only a
triangle¿? How can I get correctly the x,y and z of each triangle¿?¿
Thank you a lot in advance!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Help-getting-triangles-coordinates-from-Delaunay-Triangulation-tp3955310p3955310.html
