Re: [cgal-discuss] Re: Help getting triangles coordinates from Delaunay Triangulation
- To:
- Subject: Re: [cgal-discuss] Re: Help getting triangles coordinates from Delaunay Triangulation
- Date: Mon, 31 Oct 2011 12:26:37 +0100
horstmann wrote:
Thank you for the fast answer,
but I still don't know how to iterate over the resulting triangles, and how
to get the indexes of the vertices of each triangles. As I said before, I
need something like that:
triangle_1 v1 v2 v3
triangle_2 v1 v3 v4
triangle_3 v2 v4 v5
and so on. (At the moment, I'm not interested in the vertices x,y,z
coordinates, but its indexes)
Thank you again in advance.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Help-getting-triangles-coordinates-from-Delaunay-Triangulation-tp3955310p3955454.html
Look at these examples to associate an integer to vertices of the triangulation:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_3/Chapter_main.html
Then instead of calling
it->first->vertex( (it->second+k)%4 )->point()
do
it->first->vertex( (it->second+k)%4 )->info()
To get convex hull facets, use
t.incident_cells (t.infinite_vertex(),OutputIterator) const
here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_3_ref/Class_Triangulation_3.html#Cross_link_anchor_1344
The index of the infinite vertex is given using the function index of Cell like this: cell_handle->index(t.infinite_vertex())
documentation is here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/TriangulationDS_3_ref/Concept_TriangulationDataStructure_3--Cell.html
Sebastien.
- [cgal-discuss] Help getting triangles coordinates from Delaunay Triangulation, horstmann, 10/31/2011
- Re: [cgal-discuss] Help getting triangles coordinates from Delaunay Triangulation, Sebastien Loriot (GeometryFactory), 10/31/2011
- [cgal-discuss] Re: Help getting triangles coordinates from Delaunay Triangulation, horstmann, 10/31/2011
- [cgal-discuss] Re: Help getting triangles coordinates from Delaunay Triangulation, adam.hopkins83, 10/31/2011
- Re: [cgal-discuss] Re: Help getting triangles coordinates from Delaunay Triangulation, Sebastien Loriot (GeometryFactory), 10/31/2011
