[cgal-discuss] Re: Help getting triangles coordinates from Delaunay Triangulation
- To:
- Subject: [cgal-discuss] Re: Help getting triangles coordinates from Delaunay Triangulation
- Date: Mon, 31 Oct 2011 04:23:20 -0700 (PDT)
Hi
This is a 3D case, but you need to follow the same idea:
ITERATING THE VERTICES and creating a list with their indixes:
std::map<Vertex_handle, int> Vertices;
int index = 1;
for (Finite_vertices_iterator vit = T.finite_vertices_begin(), end =
T.finite_vertices_end(); vit != end; ++vit)
Vertices[vit] = index;
index++;
ITERATING THE CELLS:
std::map<Cell_handle, int> Cells;
std::map<Cell_handle, std::list<int>> Cells_Test;
int index_aux = 0;
for(Finite_cells_iterator cit = T.finite_cells_begin(), end =
T.finite_cells_end(); cit != end; ++cit)
int V1ind = Vertices.find(cit->vertex(0))->second
int V2ind = Vertices.find(cit->vertex(1))->second
int V3ind = Vertices.find(cit->vertex(2))->second
int V4ind = Vertices.find(cit->vertex(3))->second
maybe is the same for 2D case
Best regard
Adam.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Help-getting-triangles-coordinates-from-Delaunay-Triangulation-tp3955310p3955492.html
- [cgal-discuss] Help getting triangles coordinates from Delaunay Triangulation, horstmann, 10/31/2011
- Re: [cgal-discuss] Help getting triangles coordinates from Delaunay Triangulation, Sebastien Loriot (GeometryFactory), 10/31/2011
- [cgal-discuss] Re: Help getting triangles coordinates from Delaunay Triangulation, horstmann, 10/31/2011
- [cgal-discuss] Re: Help getting triangles coordinates from Delaunay Triangulation, adam.hopkins83, 10/31/2011
- Re: [cgal-discuss] Re: Help getting triangles coordinates from Delaunay Triangulation, Sebastien Loriot (GeometryFactory), 10/31/2011
