- To:
- Subject: Re: [cgal-discuss] Computing Time Triangulation_3 vs Delaunay_triangulation_3
- Date: Thu, 24 Nov 2011 09:46:27 +0200
Le 24/11/11 09:34, Andreas Fabri a écrit :
On 24/11/2011 00:26, Juan Carlos Lopez Alfonso wrote:
Hi all:
The documentation of Triangulation_3 says that constructions of Delaunay
triangulations with more than 10^7 points is compute in 87.4 seconds. In
my case, I have a set of points (3 500 000) in parallel planes and the
computing time is much greater than this (hours). On the other hand, the
same code in the same computer for a Triangulation_3 work very fast
(minutes), but for Delaunay_triangulation_3 is very slow and throw an
alloc exception (problem with memory).
Please, could anyone explain me the reasons of this problems?
Best regards and thank in advance
Juan Carlos
Hello,
The word parallel planes makes ring a bell.
If you insert the points one by one, and start with
points on plane A, and later insert those of plane B,
the first insertions of point in plane B, will
have huge conflict zones: for the first point
it are all "triangles" you have constructed so far.
Inserting all points with the insert function
that takes a range of points avoids that.
Yes. That's also why I asked about spatial sorting. The insert function taking a range of points actually uses spatial sorting (as documented).
There might be an additional problem, namely that
many orientation and insphere tests will be performed
with exact arithmetic.
In fact I expect that the use of spatial sorting is going to reduce the number of calls to exact arithmetic.
Can you send me your data set.
I ask because we work on a solution for that.
indeed, having a closer look can be interesting.
Monique Teillaud
INRIA Sophia Antipolis - Méditerranée
http://www.inria.fr/sophia/members/Monique.Teillaud/
- [cgal-discuss] Computing Time Triangulation_3 vs Delaunay_triangulation_3, Juan Carlos Lopez Alfonso, 11/24/2011
- Re: [cgal-discuss] Computing Time Triangulation_3 vs Delaunay_triangulation_3, Monique Teillaud, 11/24/2011
- Re: [cgal-discuss] Computing Time Triangulation_3 vs Delaunay_triangulation_3, Juan Carlos Lopez Alfonso, 11/24/2011
- Re: [cgal-discuss] Computing Time Triangulation_3 vs Delaunay_triangulation_3, Olivier Devillers, 11/24/2011
- Re: [cgal-discuss] Computing Time Triangulation_3 vs Delaunay_triangulation_3, Andreas Fabri, 11/24/2011
- Re: [cgal-discuss] Computing Time Triangulation_3 vs Delaunay_triangulation_3, Daniel Duque, 11/25/2011
- Re: [cgal-discuss] Computing Time Triangulation_3 vs Delaunay_triangulation_3, Louis Lavery, 11/25/2011
- Re: [cgal-discuss] Computing Time Triangulation_3 vs Delaunay_triangulation_3, Andreas Fabri, 11/25/2011
