- To:
- Subject: [cgal-discuss] Re: CGAL error in Skin_surface_base_3
- Date: Tue, 29 Nov 2011 23:26:21 +0100
- Resent-date: Wed, 30 Nov 2011 07:37:50 +0100
- Resent-from: François-Xavier Coudert <>
- Resent-message-id: <>
- Resent-to:
Sorry for the first email, which was incomplete. I didn't even quote the
error message! The code described below compiles OK, but when run it gives:
CGAL error: assertion violation!
Expression :
File : /opt/CGAL-3.9/include/CGAL/Skin_surface_base_3.h
Line : 483
Explanation: intersection: no intersection.
Can someone help me track down that issue?
Thanks in advance,
FX
Le 29 nov. 2011 à 13:05, FX a écrit :
> Dear CGAL team and users,
> I have encountered an assertion violation in CGAL's meshing the union of a
> set of balls. I have reduced my much larger original code to a minimal
> testcase that always fails on my system. The following testcase tries to
> mesh the union of 4 balls:
>> #include <CGAL/Exact_predicates_inexact_constructions_kernel.h>
>> #include <CGAL/Skin_surface_3.h>
>> #include <CGAL/Union_of_balls_3.h>
>> #include <CGAL/Polyhedron_3.h>
>> #include <CGAL/mesh_skin_surface_3.h>
>> #include <CGAL/subdivide_skin_surface_mesh_3.h>
>> #include <CGAL/IO/Polyhedron_iostream.h>
>> int main (void)
>> typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
>> typedef CGAL::Skin_surface_traits_3<K> Traits;
>> typedef CGAL::Union_of_balls_3<Traits> Skin_surface_3;
>> typedef Skin_surface_3::FT FT;
>> typedef Skin_surface_3::Weighted_point Weighted_point;
>> typedef Weighted_point::Point Bare_point;
>> typedef CGAL::Polyhedron_3<K,
>> CGAL::Skin_surface_polyhedral_items_3<Skin_surface_3> > Polyhedron;
>> std::list<Weighted_point> list;
>> list.push_front(Weighted_point(Bare_point(0.30700, 6.45800, 6.45800),
>> 1));
>> list.push_front(Weighted_point(Bare_point(0.07400, 5.03900, 5.03900),
>> 1));
>> list.push_front(Weighted_point(Bare_point(0.30700, 19.37400, 19.37400),
>> 1));
>> list.push_front(Weighted_point(Bare_point(0.07400, 20.79300, 20.79300),
>> 1));
>> Polyhedron p;
>> Skin_surface_3 skin_surface(list.begin(), list.end());
>> CGAL::mesh_skin_surface_3(skin_surface, p);
>> CGAL::subdivide_skin_surface_mesh_3(skin_surface, p, 1);
>> std::cout << "Mesh has " << p.size_of_facets() << " facets" << std::endl;
>> return 0;
> I compile it against CGAL-3.9 on a x86_64 Mac OS 10.7 system, with Apple's
> default G++ 4.2.1 compiler. Boost is 1.46.1, GMP is 5.0.2, MPFR is 3.1.0 (+
> available patches). The compilation command-line is:
>> g++ bug.cpp -I/opt/CGAL-3.9/include -I/opt/boost-1.46.1/include
>> -L/opt/CGAL-3.9/lib -lCGAL -L/opt/boost-1.46.1/lib -lboost_thread -lmpfr
>> -lgmp -frounding-math && ./a.out
> I hope you can help me understand what's going wrong, and whether I used
> the CGAL functions right (I tried to stick to the examples as much as
> possible).
> Thanks in advance,
> FX Coudert
> PS: the CGAL doc says that GMP and MPFR are recommended, implying that
> building without them is possible. However, when I tried to do so, the
> build system complains that CGAL_Core depends on GMP, and compilation will
> not succeed. Did I miss something?
Dr. François-Xavier Coudert
CNRS & Chimie ParisTech
http://www.chimie-paristech.fr/molsim/
Phone: +33 1 44 27 65 99 / +33 6 28 04 58 18
- [cgal-discuss] CGAL error in Skin_surface_base_3, FX, 11/29/2011
- [cgal-discuss] Re: CGAL error in Skin_surface_base_3, François-Xavier Coudert, 11/30/2011
- Re: [cgal-discuss] Re: CGAL error in Skin_surface_base_3, Sebastien Loriot (GeometryFactory), 11/30/2011
- Re: [cgal-discuss] CGAL error in Skin_surface_base_3, FX, 11/30/2011
- Re: [cgal-discuss] CGAL error in Skin_surface_base_3, Sebastien Loriot (GeometryFactory), 11/30/2011
