cgal-discuss - Re: [cgal-discuss] CGAL error in Skin_surface_base_3
  • To:
  • Subject: Re: [cgal-discuss] CGAL error in Skin_surface_base_3
  • Date: Wed, 30 Nov 2011 11:38:49 +0100
FX wrote:
Hi Sebastien,
This algorithm requires constructions so you need to use an Kernel with
exact constructions (http://www.cgal.org/FAQ.html#inexact_NT).
Replacing Exact_predicates_inexact_constructions_kernel by
Exact_predicates_exact_constructions_kernel makes your example
running fine on my machine.
So it does on mine. Many thanks for this fast reply! May I suggest that the
examples of 3D skin surface meshing in the documentation be fixed also (they
use the inexact constructions kernel, see 49.5.1 and 49.5.2 at
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Skin_surface_3/Chapter_main.html)?
Also, after reading the FAQ you pointed to and looking up the relevant
headers, I concluded that Exact_predicates_exact_constructions_kernel uses a
lazy kernel by default (which suits me fine, of course), unless
CGAL_DONT_USE_LAZY_KERNEL is defined before including headers. Is that
assessment correct? Or is there more to it?
Yes, when CGAL_DONT_USE_LAZY_KERNEL is defined, it deactivates the
Lazy_kernel and only use a lazy but exact number type.
Sebastien.
Many thanks again,
FX Coudert
