- To:
- Subject: Re: [cgal-discuss] CGAL error in Skin_surface_base_3
- Date: Wed, 30 Nov 2011 10:28:05 +0100
Hi Sebastien,
> This algorithm requires constructions so you need to use an Kernel with
> exact constructions (http://www.cgal.org/FAQ.html#inexact_NT).
> Replacing Exact_predicates_inexact_constructions_kernel by
> Exact_predicates_exact_constructions_kernel makes your example
> running fine on my machine.
So it does on mine. Many thanks for this fast reply! May I suggest that the
examples of 3D skin surface meshing in the documentation be fixed also (they
use the inexact constructions kernel, see 49.5.1 and 49.5.2 at
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Skin_surface_3/Chapter_main.html)?
Also, after reading the FAQ you pointed to and looking up the relevant
headers, I concluded that Exact_predicates_exact_constructions_kernel uses a
lazy kernel by default (which suits me fine, of course), unless
CGAL_DONT_USE_LAZY_KERNEL is defined before including headers. Is that
assessment correct? Or is there more to it?
Many thanks again,
FX Coudert
- [cgal-discuss] CGAL error in Skin_surface_base_3, FX, 11/29/2011
- [cgal-discuss] Re: CGAL error in Skin_surface_base_3, François-Xavier Coudert, 11/30/2011
- Re: [cgal-discuss] Re: CGAL error in Skin_surface_base_3, Sebastien Loriot (GeometryFactory), 11/30/2011
- Re: [cgal-discuss] CGAL error in Skin_surface_base_3, FX, 11/30/2011
- Re: [cgal-discuss] CGAL error in Skin_surface_base_3, Sebastien Loriot (GeometryFactory), 11/30/2011
