Re: [cgal-discuss] Re: Constraint Delaunay Triangulation: How to triangulate a set of polygons
- To:
- Subject: Re: [cgal-discuss] Re: Constraint Delaunay Triangulation: How to triangulate a set of polygons
- Date: Tue, 06 Dec 2011 09:42:21 +0100
I did not mean to use the code directly. I meant to use only the connected component exploration part which is the same in the example
and in your case (you don't need the nesting level which is invalid
since polygons can share edges in your setting).
Sebastien.
Graviton wrote:
Hi Sebastian, I tried your algorithm, and it works for a lot of cases, but
there are cases that it couldn't work. You can try the following code:
#include <CGAL/Exact_predicates_inexact_constructions_kernel.h> #include <CGAL/Constrained_Delaunay_triangulation_2.h> #include <CGAL/Triangulation_face_base_with_info_2.h> #include <CGAL/Polygon_2.h> #include <boost/next_prior.hpp> #include <iostream>
struct FaceInfo2 { FaceInfo2(){} int nesting_level;
bool in_domain(){ return nesting_level%2 == 1; } };
typedef CGAL::Exact_predicates_inexact_constructions_kernel K; typedef CGAL::Triangulation_vertex_base_2<K> Vb; typedef CGAL::Triangulation_face_base_with_info_2<FaceInfo2,K> Fbb; typedef CGAL::Constrained_triangulation_face_base_2<K,Fbb> Fb; typedef CGAL::Triangulation_data_structure_2<Vb,Fb> TDS; typedef CGAL::Exact_predicates_tag Itag; typedef CGAL::Constrained_Delaunay_triangulation_2<K, TDS, Itag> CDT; typedef CDT::Point Point; typedef CGAL::Polygon_2<K> Polygon;
void mark_domains(CDT& ct, CDT::Face_handle start, int index, std::list<CDT::Edge>& border ) { if(start->info().nesting_level != -1){ return; } std::list<CDT::Face_handle> queue; queue.push_back(start);
while(! queue.empty()){ CDT::Face_handle fh = queue.front(); queue.pop_front(); if(fh->info().nesting_level == -1){ fh->info().nesting_level = index; for(int i = 0; i < 3; i++){ CDT::Edge e(fh,i); CDT::Face_handle n = fh->neighbor(i); if(n->info().nesting_level == -1){ if(ct.is_constrained(e)) border.push_back(e); else queue.push_back(n); } } } } }
//explore set of facets connected with non constrained edges, //and attribute to each such set a nesting level. //We start from facets incident to the infinite vertex, with a nesting //level of 0. Then we recursively consider the non-explored facets incident //to constrained edges bounding the former set and increase the nesting
level by 1. //Facets in the domain are those with an odd nesting level. void mark_domains(CDT& cdt) { for(CDT::All_faces_iterator it = cdt.all_faces_begin(); it !=
cdt.all_faces_end(); ++it){ it->info().nesting_level = -1; }
int index = 0; std::list<CDT::Edge> border; mark_domains(cdt, cdt.infinite_face(), index++, border); while(! border.empty()){ CDT::Edge e = border.front(); border.pop_front(); CDT::Face_handle n = e.first->neighbor(e.second); if(n->info().nesting_level == -1){ mark_domains(cdt, n, e.first->info().nesting_level+1, border); } } }
void insert_polygon(CDT& cdt,const Polygon& polygon){ if ( polygon.is_empty() ) return; CDT::Vertex_handle
v_prev=cdt.insert(*boost::prior(polygon.vertices_end())); for (Polygon::Vertex_iterator vit=polygon.vertices_begin(); vit!=polygon.vertices_end();++vit) { CDT::Vertex_handle vh=cdt.insert(*vit); cdt.insert_constraint(vh,v_prev); v_prev=vh; } }
int main( ) { //construct two non-intersecting nested polygons Polygon polygon1; polygon1.push_back(Point(254250, 173750)); polygon1.push_back(Point(257250, 139250)); polygon1.push_back(Point(259750, 133750)); polygon1.push_back(Point(261250, 136250)); polygon1.push_back(Point(257750, 176250));
Polygon polygon2; polygon2.push_back(Point(254750, 122750)); polygon2.push_back(Point(312750, 93750)); polygon2.push_back(Point(317750, 104750)); polygon2.push_back(Point(303750, 111750)); polygon2.push_back(Point(259750, 133750));
Polygon polygon3; polygon3.push_back(Point(261250, 136250)); polygon3.push_back(Point(259750, 133750)); polygon3.push_back(Point(303750, 111750)); polygon3.push_back(Point(315750, 145750)); polygon3.push_back(Point(257750, 176250));
Polygon polygon4; polygon4.push_back(Point(303750, 111750)); polygon4.push_back(Point(317750, 104750)); polygon4.push_back(Point(321250, 102750)); polygon4.push_back(Point(327250, 105250)); polygon4.push_back(Point(338750, 137250)); polygon4.push_back(Point(315750, 145750));
Polygon polygon5; polygon5.push_back(Point(251250, 179750)); polygon5.push_back(Point(257750, 176250)); polygon5.push_back(Point(315750, 145750)); polygon5.push_back(Point(329750, 183750)); polygon5.push_back(Point(272250, 223750));
//Insert the polyons into a constrained triangulation CDT cdt; insert_polygon(cdt,polygon1); insert_polygon(cdt,polygon2); insert_polygon(cdt,polygon3); insert_polygon(cdt,polygon4);
insert_polygon(cdt,polygon5); //insert_polygon(cdt,polygon2); //Mark facets that are inside the domain bounded by the polygon mark_domains(cdt); int count=0; for (CDT::Finite_faces_iterator fit=cdt.finite_faces_begin(); fit!=cdt.finite_faces_end();++fit) { if ( fit->info().in_domain() ) ++count; } std::cout << "There are " << count << " facets in the domain." <<
std::endl; // should be 16, but instead it is 13 only
return 0; }
I also attach a screenshot of the polygon set for easier visual checking. http://cgal-discuss.949826.n4.nabble.com/file/n4163918/image001.png
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Constraint-Delaunay-Triangulation-How-to-triangulate-a-set-of-polygons-tp4122741p4163918.html
- [cgal-discuss] Re: Constraint Delaunay Triangulation: How to triangulate a set of polygons, Graviton, 12/06/2011
- Re: [cgal-discuss] Re: Constraint Delaunay Triangulation: How to triangulate a set of polygons, Sebastien Loriot (GeometryFactory), 12/06/2011
- Re: [cgal-discuss] Re: Constraint Delaunay Triangulation: How to triangulate a set of polygons, Sebastien Loriot (GeometryFactory), 12/07/2011
