Re: [cgal-discuss] Re: Constraint Delaunay Triangulation: How to triangulate a set of polygons
- To:
- Subject: Re: [cgal-discuss] Re: Constraint Delaunay Triangulation: How to triangulate a set of polygons
- Date: Wed, 07 Dec 2011 08:50:19 +0100
If an edge is shared by two polygons, the endpoints are vertices of both polygons.
Upon insertion of a point in the CDT, you can get the corresponding
vertex handle, and for an edge a pair of vertex handle. If you sort
the pair, then you have a unique id per edge. You can use a std::set for
example or a std::map to track shared edges.
Sebastien.
Graviton wrote:
* then you need to modify a little bit the code and increase the nesting level only if the constrained edge is not shared by two polygons. *
This is something I don't quite understand, when we are doing the mark_domains, we don't yet know whether a constrained edge is shared by two mesh elements (AKA face) or not ( this is the whole purpose of mark_domains). If this were the case how can we know a constrained edge is shared by one or two polygons?
Do I miss something?
On Tue, Dec 6, 2011 at 5:45 PM, Sebastien Loriot (GeometryFactory) [via cgal-discuss] <[hidden email] </user/SendEmail.jtp?type=node&node=4164287&i=0>> wrote:
oops! I thought this was the mesh thread.
The code given is working if polygons are not intersecting.
If they can share an edge, then you need to modify a little bit the
code
here:
mark_domains(cdt, n, e.first->info().nesting_level+1, border);
do +1 only if e is not shared by two polygons.
Sebastien.
Graviton wrote:
> Hi Sebastien, thanks for your pointer.
> But I still don't quite understand the phase "you don't need the
> nesting level which is invalid
> since polygons can share edges in your setting", does that mean
that now
> I don't need the nesting level ( i.e, a face is considered "in
domain"
> if nesting level>=1)? Any idea how to modify the above code to
make sure
> it works for the above case and the case when there is a hole
inside the
> polygon set?
> On Tue, Dec 6, 2011 at 4:43 PM, Sebastien Loriot
> </user/SendEmail.jtp?type=node&node=4164051&i=0>> wrote:
> I did not mean to use the code directly. I meant to use only the
> connected component exploration part which is the same in the
example
> and in your case (you don't need the nesting level which is
invalid
> since polygons can share edges in your setting).
> Sebastien.
> Graviton wrote:
> > Hi Sebastian, I tried your algorithm, and it works for a
lot of
> cases, but
> > there are cases that it couldn't work. You can try the
following
> code:
> > #include
<CGAL/Exact_predicates_inexact_constructions_kernel.h>
> > #include <CGAL/Constrained_Delaunay_triangulation_2.h>
> > #include <CGAL/Triangulation_face_base_with_info_2.h>
> > #include <CGAL/Polygon_2.h>
> > #include <boost/next_prior.hpp>
> > #include <iostream>
> > struct FaceInfo2
> > FaceInfo2(){}
> > int nesting_level;
> > bool in_domain(){
> > return nesting_level%2 == 1;
> > typedef
CGAL::Exact_predicates_inexact_constructions_kernel K;
> > typedef CGAL::Triangulation_vertex_base_2<K> > Vb;
> > typedef
CGAL::Triangulation_face_base_with_info_2<FaceInfo2,K> > Fbb;
> > typedef CGAL::Constrained_triangulation_face_base_2<K,Fbb>
> Fb;
> > typedef CGAL::Triangulation_data_structure_2<Vb,Fb> > TDS;
> > typedef CGAL::Exact_predicates_tag > Itag;
> > typedef CGAL::Constrained_Delaunay_triangulation_2<K, TDS,
Itag>
> CDT;
> > typedef CDT::Point > Point;
> > typedef CGAL::Polygon_2<K> > Polygon;
> > void
> > mark_domains(CDT& ct,
> > CDT::Face_handle start,
> > int index,
> > std::list<CDT::Edge>& border )
> > if(start->info().nesting_level != -1){
> > return;
> > std::list<CDT::Face_handle> queue;
> > queue.push_back(start);
> > while(! queue.empty()){
> > CDT::Face_handle fh = queue.front();
> > queue.pop_front();
> > if(fh->info().nesting_level == -1){
> > fh->info().nesting_level = index;
> > for(int i = 0; i < 3; i++){
> > CDT::Edge e(fh,i);
> > CDT::Face_handle n = fh->neighbor(i);
> > if(n->info().nesting_level == -1){
> > if(ct.is_constrained(e)) border.push_back(e);
> > else queue.push_back(n);
> > //explore set of facets connected with non constrained edges,
> > //and attribute to each such set a nesting level.
> > //We start from facets incident to the infinite vertex,
with a
> nesting
> > //level of 0. Then we recursively consider the non-explored
> facets incident
> > //to constrained edges bounding the former set and
increase the
> nesting
> > level by 1.
> > //Facets in the domain are those with an odd nesting level.
> > void
> > mark_domains(CDT& cdt)
> > for(CDT::All_faces_iterator it = cdt.all_faces_begin();
it !=
> > cdt.all_faces_end(); ++it){
> > it->info().nesting_level = -1;
> > int index = 0;
> > std::list<CDT::Edge> border;
> > mark_domains(cdt, cdt.infinite_face(), index++, border);
> > while(! border.empty()){
> > CDT::Edge e = border.front();
> > border.pop_front();
> > CDT::Face_handle n = e.first->neighbor(e.second);
> > void insert_polygon(CDT& cdt,const Polygon& polygon){
> > if ( polygon.is_empty() ) return;
> > CDT::Vertex_handle
> > v_prev=cdt.insert(*boost::prior(polygon.vertices_end()));
> > for (Polygon::Vertex_iterator vit=polygon.vertices_begin();
> > vit!=polygon.vertices_end();++vit)
> > CDT::Vertex_handle vh=cdt.insert(*vit);
> > cdt.insert_constraint(vh,v_prev);
> > v_prev=vh;
> > int main( )
> > //construct two non-intersecting nested polygons > > Polygon polygon1;
> > polygon1.push_back(Point(254250, 173750));
> > polygon1.push_back(Point(257250, 139250));
> > polygon1.push_back(Point(259750, 133750));
> > polygon1.push_back(Point(261250, 136250));
> > polygon1.push_back(Point(257750, 176250));
> > Polygon polygon2;
> > polygon2.push_back(Point(254750, 122750));
> > polygon2.push_back(Point(312750, 93750));
> > polygon2.push_back(Point(317750, 104750));
> > polygon2.push_back(Point(303750, 111750));
> > polygon2.push_back(Point(259750, 133750));
> > Polygon polygon3;
> > polygon3.push_back(Point(261250, 136250));
> > polygon3.push_back(Point(259750, 133750));
> > polygon3.push_back(Point(303750, 111750));
> > polygon3.push_back(Point(315750, 145750));
> > polygon3.push_back(Point(257750, 176250));
> > Polygon polygon4;
> > polygon4.push_back(Point(303750, 111750));
> > polygon4.push_back(Point(317750, 104750));
> > polygon4.push_back(Point(321250, 102750));
> > polygon4.push_back(Point(327250, 105250));
> > polygon4.push_back(Point(338750, 137250));
> > polygon4.push_back(Point(315750, 145750));
> > Polygon polygon5;
> > polygon5.push_back(Point(251250, 179750));
> > polygon5.push_back(Point(257750, 176250));
> > polygon5.push_back(Point(315750, 145750));
> > polygon5.push_back(Point(329750, 183750));
> > polygon5.push_back(Point(272250, 223750));
> > //Insert the polyons into a constrained triangulation
> > CDT cdt;
> > insert_polygon(cdt,polygon1);
> > insert_polygon(cdt,polygon2);
> > insert_polygon(cdt,polygon3);
> > insert_polygon(cdt,polygon4);
> > insert_polygon(cdt,polygon5);
> > //insert_polygon(cdt,polygon2);
> > > > //Mark facets that are inside the domain bounded by the
polygon
> > mark_domains(cdt);
> > > > int count=0;
> > for (CDT::Finite_faces_iterator
fit=cdt.finite_faces_begin();
> > fit!=cdt.finite_faces_end();++fit)
> > if ( fit->info().in_domain() ) ++count;
> > > > std::cout << "There are " << count << " facets in the
domain." <<
> > std::endl; // should be 16, but instead it is 13 only
> > return 0;
> > I also attach a screenshot of the polygon set for easier
visual
> checking.
http://cgal-discuss.949826.n4.nabble.com/file/n4163918/image001.png > >
> > View this message in context:
> http://cgal-discuss.949826.n4.nabble.com/Constraint-Delaunay-Triangulation-How-to-triangulate-a-set-of-polygons-tp4122741p4163918.html
> > Sent from the cgal-discuss mailing list archive at
Nabble.com.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
> If you reply to this email, your message will be added to the
> discussion below:
> http://cgal-discuss.949826.n4.nabble.com/Constraint-Delaunay-Triangulation-How-to-triangulate-a-set-of-polygons-tp4122741p4163927.html
> To unsubscribe from Constraint Delaunay Triangulation: How to
> triangulate a set of polygons, click here.
> NAML
> <http://cgal-discuss.949826.n4.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.InstantMailNamespace&breadcrumbs=instant+emails%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml
<http://cgal-discuss.949826.n4.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.InstantMailNamespace&breadcrumbs=instant+emails%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>>
> View this message in context: Re: Constraint Delaunay
Triangulation: How
<http://cgal-discuss.949826.n4.nabble.com/Constraint-Delaunay-Triangulation-How-to-triangulate-a-set-of-polygons-tp4122741p4164051.html>
> <http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com.
-- You are currently subscribed to cgal-discuss.
discussion below:
http://cgal-discuss.949826.n4.nabble.com/Constraint-Delaunay-Triangulation-How-to-triangulate-a-set-of-polygons-tp4122741p4164067.html
NAML
View this message in context: Re: Constraint Delaunay Triangulation: How to triangulate a set of polygons <http://cgal-discuss.949826.n4.nabble.com/Constraint-Delaunay-Triangulation-How-to-triangulate-a-set-of-polygons-tp4122741p4164287.html>
Sent from the cgal-discuss mailing list archive <http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com.
- [cgal-discuss] Re: Constraint Delaunay Triangulation: How to triangulate a set of polygons, Graviton, 12/06/2011
- Re: [cgal-discuss] Re: Constraint Delaunay Triangulation: How to triangulate a set of polygons, Sebastien Loriot (GeometryFactory), 12/06/2011
- Re: [cgal-discuss] Re: Constraint Delaunay Triangulation: How to triangulate a set of polygons, Sebastien Loriot (GeometryFactory), 12/07/2011
