- To:
- Subject: Re: [cgal-discuss] surface remeshing/polyhedron problems
- Date: Wed, 04 Jan 2012 17:53:47 +0100
Don't know if it's related but you do have a self intersection in the
.off provided. You can use in the Polyhedron demo the
"Self intersection " operation to see where it is.
Sebastien.
Richard Downe wrote:
I'm using the AABB_polyhedral_oracle surface meshing demo code to remesh a surface -- basically, I combine 2 or more (6 or 7 is the high side of what is common) disjoint tubular meshes using NEF_polyhedron. The .off file I get when I write the NEF_polyhedron to a file is clean, with no self intersections, and I can view it in tecplot without difficulty.
The problem comes with the remeshing -- I remesh to smooth the surface and guarantee that my triangles are as regular as possible, etc., since the downstream processing is computational fluid dynamics. Most surfaces work fine. The attached surface I continually get
File: /usr/include/CGAL/Surface_mesher/Surface_mesher.h
Line: 248
Explanation: (0.0200637 0.0244694 0.0292433) is already inserted on surface.
in spite of the fact that the .off file appears to be fine.
If I set Tag to Non_manifold, it meshes successfully, but the output surface contains a patch where some of the facets are reversed. I feel as though this provides some insight into what might be wrong/breaking, but I don't know enough to intelligently pursue it further. Wondered if anyone else might have insight.
Attached is the .off file from the NEF_polyhedron pre-remshing. I can supply the final mesh as well, but it is quite large, and sending both will put me over the attachments size limit, thus if anyone would like to see it, let me know and I'll send it along separately.
Thanks.
--rd
- [cgal-discuss] surface remeshing/polyhedron problems, Richard Downe, 01/02/2012
- Re: [cgal-discuss] surface remeshing/polyhedron problems, Sebastien Loriot (GeometryFactory), 01/04/2012
- Re: [cgal-discuss] surface remeshing/polyhedron problems, Downe, Richard W, 01/05/2012
- Re: [cgal-discuss] surface remeshing/polyhedron problems, Sebastien Loriot (GeometryFactory), 01/05/2012
- Re: [cgal-discuss] surface remeshing/polyhedron problems, Richard Downe, 01/05/2012
