cgal-discuss - Re: [cgal-discuss] surface remeshing/polyhedron problems
  • To:
  • Subject: Re: [cgal-discuss] surface remeshing/polyhedron problems
  • Date: Thu, 05 Jan 2012 07:08:12 +0100
Downe, Richard W wrote:
Ah. I naively assumed that a Nef polyhedron guaranteed no self intersections.
It should, I think in your case this is due to the output precision of double.
Sebastien.
Is there a way to achieve this with Nef polyhedrons? Else...is there a
workable technique for pruning self intersections without forfeiting
manifoldness?
-rd
"Sebastien Loriot (GeometryFactory)"
wrote:
Don't know if it's related but you do have a self intersection in the
.off provided. You can use in the Polyhedron demo the
"Self intersection " operation to see where it is.
Sebastien.
Richard Downe wrote:
I'm using the AABB_polyhedral_oracle surface meshing demo code to remesh
a surface -- basically, I combine 2 or more (6 or 7 is the high side of
what is common) disjoint tubular meshes using NEF_polyhedron. The .off
file I get when I write the NEF_polyhedron to a file is clean, with no
self intersections, and I can view it in tecplot without difficulty.
The problem comes with the remeshing -- I remesh to smooth the surface
and guarantee that my triangles are as regular as possible, etc., since
the downstream processing is computational fluid dynamics. Most
surfaces work fine. The attached surface I continually get
File: /usr/include/CGAL/Surface_mesher/Surface_mesher.h
Line: 248
Explanation: (0.0200637 0.0244694 0.0292433) is already inserted on
surface.
in spite of the fact that the .off file appears to be fine.
If I set Tag to Non_manifold, it meshes successfully, but the output
surface contains a patch where some of the facets are reversed. I feel
as though this provides some insight into what might be wrong/breaking,
but I don't know enough to intelligently pursue it further. Wondered if
anyone else might have insight.
Attached is the .off file from the NEF_polyhedron pre-remshing. I can
supply the final mesh as well, but it is quite large, and sending both
will put me over the attachments size limit, thus if anyone would like
to see it, let me know and I'll send it along separately.
Thanks.
--rd
