- To: "" <>
- Subject: Re: [cgal-discuss] surface remeshing/polyhedron problems
- Date: Wed, 4 Jan 2012 23:19:37 +0000
- Accept-language: en-US
Ah. I naively assumed that a Nef polyhedron guaranteed no self intersections.
Is there a way to achieve this with Nef polyhedrons? Else...is there a
workable technique for pruning self intersections without forfeiting
manifoldness?
-rd
"Sebastien Loriot (GeometryFactory)"
wrote:
Don't know if it's related but you do have a self intersection in the
.off provided. You can use in the Polyhedron demo the
"Self intersection " operation to see where it is.
Sebastien.
Richard Downe wrote:
> I'm using the AABB_polyhedral_oracle surface meshing demo code to remesh
> a surface -- basically, I combine 2 or more (6 or 7 is the high side of
> what is common) disjoint tubular meshes using NEF_polyhedron. The .off
> file I get when I write the NEF_polyhedron to a file is clean, with no
> self intersections, and I can view it in tecplot without difficulty.
> The problem comes with the remeshing -- I remesh to smooth the surface
> and guarantee that my triangles are as regular as possible, etc., since
> the downstream processing is computational fluid dynamics. Most
> surfaces work fine. The attached surface I continually get
> File: /usr/include/CGAL/Surface_mesher/Surface_mesher.h
> Line: 248
> Explanation: (0.0200637 0.0244694 0.0292433) is already inserted on
> surface.
> in spite of the fact that the .off file appears to be fine.
> If I set Tag to Non_manifold, it meshes successfully, but the output
> surface contains a patch where some of the facets are reversed. I feel
> as though this provides some insight into what might be wrong/breaking,
> but I don't know enough to intelligently pursue it further. Wondered if
> anyone else might have insight.
> Attached is the .off file from the NEF_polyhedron pre-remshing. I can
> supply the final mesh as well, but it is quite large, and sending both
> will put me over the attachments size limit, thus if anyone would like
> to see it, let me know and I'll send it along separately.
> Thanks.
> --rd
- [cgal-discuss] surface remeshing/polyhedron problems, Richard Downe, 01/02/2012
- Re: [cgal-discuss] surface remeshing/polyhedron problems, Sebastien Loriot (GeometryFactory), 01/04/2012
- Re: [cgal-discuss] surface remeshing/polyhedron problems, Downe, Richard W, 01/05/2012
- Re: [cgal-discuss] surface remeshing/polyhedron problems, Sebastien Loriot (GeometryFactory), 01/05/2012
- Re: [cgal-discuss] surface remeshing/polyhedron problems, Richard Downe, 01/05/2012
