cgal-discuss - Re: [cgal-discuss] poisson_reconstruction_example can't get result
  • To:
  • Subject: Re: [cgal-discuss] poisson_reconstruction_example can't get result
  • Date: Fri, 06 Jan 2012 11:14:07 +0100
Hi,
My guess is that TAUCS is not properly installed on your machine.
On Windows, you should use CGAL installer to download and install TAUCS.
On Unix, you should download TAUCS from
https://gforge.inria.fr/frs/download.php/24628/taucs_full.tgz, then
uncompress it and run the installer.
Best regards,
Laurent Saboret
Le 06/01/2012 10:58, cetium a écrit :
i run this example with the defaut option but it shows "cant's solve Poisson
equation",taucs log outputs "Incorrect Matrix"
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/poisson-reconstruction-example-can-t-get-result-tp4268821p4268821.html
