cgal-discuss - [cgal-discuss] Removing all constraints from a constrained_triangulation_plus_2
  • To:
  • Subject: [cgal-discuss] Removing all constraints from a constrained_triangulation_plus_2
  • Date: Fri, 13 Jan 2012 08:08:19 -0800 (PST)
Hello
I am new to cgal.
I am using a Constrained_triangulation_plus_2 to generate a mesh
The problem is that I want my triangulation to evolve over time, i.e., it
must be dynamic.
So at a given time t, I must input some constraints, and I do it like this
typedef CGAL::Constrained_Delaunay_triangulation_2<K, TDS, Itag>
DelaunayCDT;
typedef CGAL::Constrained_triangulation_plus_2<DelaunayCDT> CDT;
CDT dt;
Vertex_handle va = dt.insert(Point_2(x1, y1);
Vertex_handle1 vb = dt.insert(Point_2(pc_local.points.at(i).x,
pc_local.points.at(i). y));
dt.insert_constraint(va, vb);
And I do this in a for cycle to insert several constraints.
The problem is that at iteration t+1, I need to remove all the constraints I
inserted at iteration t.
How can I do this?
I could not find any method like clear_constraints()
Thanks for the help
Miguel
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Removing-all-constraints-from-a-constrained-triangulation-plus-2-tp4292611p4292611.html
