Re: [cgal-discuss] Removing all constraints from a constrained_triangulation_plus_2
- To:
- Subject: Re: [cgal-discuss] Removing all constraints from a constrained_triangulation_plus_2
- Date: Sun, 15 Jan 2012 17:02:48 +0100
How can I do this?You can use the remove_constraint method:
I could not find any method like clear_constraints()
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2_ref/Class_Constrained_triangulation_plus_2.html#Function_void_remove_constraint6Vertex_handle_va+_Vertex_handle_vb9;
If you want to get all previously inserted constraints, have a look at constraints_begin():
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2_ref/Class_Constrained_triangulation_plus_2.html#Function_Constraint_iterator_constraints_begin69_const;
- [cgal-discuss] Removing all constraints from a constrained_triangulation_plus_2, mriem, 01/13/2012
- Re: [cgal-discuss] Removing all constraints from a constrained_triangulation_plus_2, Winnie Hellmann, 01/15/2012
- Re: [cgal-discuss] Removing all constraints from a constrained_triangulation_plus_2, Miguel Oliveira, 01/16/2012
