Re: [cgal-discuss] Removing all constraints from a constrained_triangulation_plus_2
- To:
- Subject: Re: [cgal-discuss] Removing all constraints from a constrained_triangulation_plus_2
- Date: Mon, 16 Jan 2012 10:12:36 +0000
- Organization: UA
Thanks Winnie
I will do as you suggest
Miguel
On Sun, 2012-01-15 at 17:02 +0100, Winnie Hellmann wrote:
> > How can I do this?
> > I could not find any method like clear_constraints()
> You can use the remove_constraint method:
> http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2_ref/Class_Constrained_triangulation_plus_2.html#Function_void_remove_constraint6Vertex_handle_va+_Vertex_handle_vb9;
> If you want to get all previously inserted constraints, have a look at
> constraints_begin():
> http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2_ref/Class_Constrained_triangulation_plus_2.html#Function_Constraint_iterator_constraints_begin69_const;
- [cgal-discuss] Removing all constraints from a constrained_triangulation_plus_2, mriem, 01/13/2012
- Re: [cgal-discuss] Removing all constraints from a constrained_triangulation_plus_2, Winnie Hellmann, 01/15/2012
- Re: [cgal-discuss] Removing all constraints from a constrained_triangulation_plus_2, Miguel Oliveira, 01/16/2012
