- To:
- Subject: [cgal-discuss] Re: Mesh generation question
- Date: Mon, 16 Jan 2012 09:55:46 -0800 (PST)
Hi Laurent,
Thanks for the quick reply. My volume of interest is just the convex hull of
the points and the segments.
Actually in my application, all I need is a unit cube that needs meshing
with points inside it. I was thinking of putting the cube as a set of
segments, but maybe you have better ideas? (Polyhedron + points?)
Thanks,
--Ram
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Mesh-generation-question-tp4300233p4300347.html
- [cgal-discuss] Mesh generation question, Ram, 01/16/2012
- Re: [cgal-discuss] Mesh generation question, Laurent Rineau (GeometryFactory), 01/16/2012
- [cgal-discuss] Re: Mesh generation question, Ram, 01/16/2012
- [cgal-discuss] Re: Mesh generation question, Ram, 01/17/2012
- Re: [cgal-discuss] Re: Mesh generation question, Laurent Rineau (GeometryFactory), 01/18/2012
- [cgal-discuss] Re: Mesh generation question, Ram, 01/18/2012
- Re: [cgal-discuss] Re: Mesh generation question, Laurent Rineau (GeometryFactory), 01/19/2012
- [cgal-discuss] Re: Mesh generation question, Ram, 01/19/2012
- Re: [cgal-discuss] Re: Mesh generation question, Laurent Rineau (GeometryFactory), 01/23/2012
- [cgal-discuss] Re: Mesh generation question, Ram, 01/25/2012
