cgal-discuss - [cgal-discuss] Re: Mesh generation question
  • To:
  • Subject: [cgal-discuss] Re: Mesh generation question
  • Date: Wed, 18 Jan 2012 11:29:38 -0800 (PST)
Hi Laurent,
Here is the code:
#include <CGAL/Mesh_triangulation_3.h>
#include <CGAL/Mesh_complex_3_in_triangulation_3.h>
#include <CGAL/Mesh_criteria_3.h>
#include <CGAL/Polyhedral_mesh_domain_with_features_3.h>
#include <CGAL/make_mesh_3.h>
#include <CGAL/convex_hull_3.h>
// Domain
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Polyhedral_mesh_domain_with_features_3<K> Mesh_domain;
typedef CGAL::Polyhedron_3<K> Polyhedron;
// Triangulation
typedef CGAL::Mesh_triangulation_3<Mesh_domain>::type Tr;
typedef CGAL::Mesh_complex_3_in_triangulation_3<
Tr,Mesh_domain::Corner_index,Mesh_domain::Curve_segment_index> C3t3;
// Criteria
typedef CGAL::Mesh_criteria_3<Tr> Mesh_criteria;
// To avoid verbose function and named parameters call
using namespace CGAL::parameters;
template <class Poly>
int make_cube_3( Poly& P) {
// appends a cube of size [0,1]^3 to the polyhedron P.
CGAL_precondition( P.is_valid());
typedef typename Poly::Point_3 Point;
std::vector<Point> cube_vertices;
std::vector<double> extents;
extents.push_back(5.0); extents.push_back(10.0);
extents.push_back(15.0);
cube_vertices.push_back(Point(0,0,0));
cube_vertices.push_back(Point(0,0,extents[2]));
cube_vertices.push_back(Point(0,extents[1],0));
cube_vertices.push_back(Point(0,extents[1],extents[2]));
cube_vertices.push_back(Point(extents[0],0,0));
cube_vertices.push_back(Point(extents[0],0,extents[2]));
cube_vertices.push_back(Point(extents[0],extents[1],0));
cube_vertices.push_back(Point(extents[0],extents[1],extents[2]));
// Returns triangulated polyhedron: Required for meshing
CGAL::convex_hull_3(cube_vertices.begin(), cube_vertices.end(), P);
return 0;
int main()
// Create domain
Polyhedron polyhedron;
make_cube_3(polyhedron);
Mesh_domain domain(polyhedron);
// Get sharp features
domain.detect_features();
// Mesh criteria
Mesh_criteria criteria(edge_size = 0.025,
facet_angle = 25, facet_size = 0.05,
facet_distance = 0.005,
cell_radius_edge_ratio = 3, cell_size = 0.05);
// Mesh generation
C3t3 c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria);
// Output
std::ofstream medit_file("out.mesh");
c3t3.output_to_medit(medit_file);
and I cant compile it. Can you please point out the problem?
Thanks,
--Ram
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Mesh-generation-question-tp4300233p4307798.html
