cgal-discuss - [cgal-discuss] Re: Mesh generation question
  • To:
  • Subject: [cgal-discuss] Re: Mesh generation question
  • Date: Wed, 25 Jan 2012 12:53:16 -0800 (PST)
Hi Laurent,
I am now iterating the tetrahedrons using:
for ( typename C3t3::Cells_in_complex_iterator cit =
c3t3.cells_in_complex_begin();
cit != c3t3.cells_in_complex_end(); ++cit){
gv << 4 << " "
<< V[cit->vertex(0)] << " "
<< V[cit->vertex(1)] << " "
<< V[cit->vertex(2)] << " "
<< V[cit->vertex(3)] << " "
<< "\n"; // without color.
// << 4 << drand48() << drand48() << drand48() << 1.0; // random
color.
With the modification you suggested, I am able to triangulate the data I
have. Here are the criterions I'm using
Mesh_criteria criteria(edge_size = 25.0,
facet_angle = 15, facet_size = 15.0,
facet_distance = 0.05,
cell_radius_edge_ratio = 3, cell_size = 50.0);
(This is just for the cube, after detect_features)
And then I insert points and then use:
Mesh_criteria new_criteria(facet_angle=20.0, cell_radius_edge=3,
cell_size=125.0);
// Mesh refinement
CGAL::refine_mesh_3(c3t3, domain, new_criteria);
But when I output, I get the attached picture (capture.jpg). What am I doing
wrong? Why these large skinny triangles on the surface?
http://cgal-discuss.949826.n4.nabble.com/file/n4328481/Capture.jpg
Thanks for the help,
--Ram.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Mesh-generation-question-tp4300233p4328481.html
