- To:
- Subject: Re: [cgal-discuss] Union of multiple Polygons
- Date: Wed, 18 Jan 2012 10:16:57 +0200
It depends on your requirements, Boolean set operation package might also be of help:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Boolean_set_operations_2/Chapter_main.html
On Jan 17, 2012 11:53 PM, "Sebastien Loriot (GeometryFactory)" <> wrote:
pgiitu wrote:
HelloThen you need to compute the arrangement induced by the polygons, the outer face will describe the union of the polygons.
I am doing a project using CGAL and I need to find the union of multiple
polygons.I should be able to get all the faces that arise out from the union
of multiple polygons.
Can any one help me on this as I need it urgently. In CGAL we have functions
to calculate the union of two polygons but I also want the faces.
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Arrangement_on_surface_2/Chapter_main.html
Sebastien.
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Union-of-multiple-Polygons-tp4304621p4304621.html
- [cgal-discuss] Union of multiple Polygons, pgiitu, 01/17/2012
- Re: [cgal-discuss] Union of multiple Polygons, Sebastien Loriot (GeometryFactory), 01/17/2012
- Re: [cgal-discuss] Union of multiple Polygons, Ophir Setter, 01/18/2012
- [cgal-discuss] Re: Union of multiple Polygons, pgiitu, 01/24/2012
- Re: [cgal-discuss] Re: Union of multiple Polygons, apurba das, 01/24/2012
- Re: [cgal-discuss] Re: Union of multiple Polygons, Winnie Hellmann, 01/24/2012
