- To:
- Subject: Re: [cgal-discuss] CGAL3.9 with QT4.8.0 on MAC Lion
- Date: Wed, 18 Jan 2012 20:03:19 +0100
Hi Roger,
it seems the issue is purely related to Qt and not CGAL. There is no way
to get the examples to run without a working Qt installation. qmake is
not required but moc (metaobject-compiler) is.
You might want to raise the issue on the appropriate Qt list or the Qt
forum.
Philipp Moeller, GeometryFactory
Roger
writes:
> Hello everybody
> Has anyone successfully compiled the examples that require QT for the
> CGAL3.9 on MAC OXS 10.7?
> My current status is:
> 1. CMAKE and BOOST installed through MACPORTS, boots works fine
> 2. CGAL 3.9 originally can't be installed smoothly either from
> macport or manual configuring and making see below
> http://cgal-discuss.949826.n4.nabble.com/
> PATCH-prevent-Qt-s-moc-from-choking-on-BOOST-JOIN-td4081602.html
> but after applying the patch for the two header files, the
> installation went without a hitch.
> Since I can't find the CGAL examples and demos folders with the
> macports install method, I directly downloaded the tarball and build
> everything myself.
> The test example is the one from cgal official manual: CGAL-3.9/
> examples/Straight_skeleton_2;
> it worked fine because output is eps file, no QT or GEOMVIEW needed.
> 3. There I got stuck with any other examples or demos that requrie QT
> libraries. Of course I tried to download it, and I followed the link
> below
> http://doc.qt.nokia.com/4.8-snapshot/install-mac.html
> 4. The problem is I can't even compile the 101 examples of qmake (I
> assume CGAL needs qmake) here. http://doc.qt.nokia.com/4.7-snapshot/
> qmake-tutorial.html
> after following the steps, what I get is a hello.app that is
> incompatible with my MAC version: lion.
> Then I realize on this download page http://qt.nokia.com/downloads/
> qt-for-open-source-cpp-development-on-mac-os-x
> the libraries are for 10.5, 10.6 rather than 10.7 lion.
> What should one do to make the examples and demos of CGAL and QT work
> on mac lion?
> Any comment is greatly appreciated.
> Roger
- [cgal-discuss] CGAL3.9 with QT4.8.0 on MAC Lion, Roger, 01/18/2012
- Re: [cgal-discuss] CGAL3.9 with QT4.8.0 on MAC Lion, Philipp Moeller, 01/18/2012
