cgal-discuss - [cgal-discuss] error MSB6006: “cmd.exe ”exit with code 1
  • To:
  • Subject: [cgal-discuss] error MSB6006: “cmd.exe ”exit with code 1
  • Date: Wed, 18 Jan 2012 17:56:47 -0800 (PST)
HI
I am a new user of CGAL.
These days I installed CGAL3.9 follow steps:
1)install boost 1_48_0
2)install QT4.8.0 by install qt-win-opensource-4.8.0-vs2010 which is
download from nokia
3) install CGAL 3.9, by CMAKE Coufigure,Generate
all these files are installed at D:
the error happened when I open D:\CGAL-3.9\Buildebug\CGAL.sln, and compile
the CGAL
But After I use CMAKE Configure, Generate,
the compile always failed with:
error 22 error MSB6006: “cmd.exe” exit with code 1。 C:\Program
(x86)\MSBuild\Microsoft.Cpp\v4.0\Microsoft.CppCommon.targets 151 6
CGAL_Qt4
if I only Compile CGAL_Qt4 project, I also get the error infomation.
Then I checked carefully the file
D:\CGAL-3.9\Buildebug\src\Qt4\CGAL_Q4.vcxproj.
and I checked the
directory:D:\CGAL-3.9\Buildebug\src\Qt4\__\__\include\CGAL\Qt
I found two files must be generated through the compile:
moc_DemosMainWindow.cpp and moc_GraphicsViewNavigation.cpp
the other files in
directory:D:\CGAL-3.9\Buildebug\src\Qt4\__\__\include\CGAL\Qt is
*.cxx_parameters files and *.cxx.rule files.
I think the error happend after the moc_DemosMainWindow.cpp and
moc_GraphicsViewNavigation.cpp has been generated.
from the CGAL_Q4.vcxproj content, I found the next step is to do something
to moc_GraphicsItem.cxx_parameters.
I don't know whether my analysis is correct.
and How to fix the error.
Thanks for any advice.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/error-MSB6006-cmd-exe-exit-with-code-1-tp4308902p4308902.html
