cgal-discuss - Re: [cgal-discuss] Re: error MSB6006: “cmd .exe”exit with code 1
  • To:
  • Subject: Re: [cgal-discuss] Re: error MSB6006: “cmd .exe”exit with code 1
  • Date: Thu, 19 Jan 2012 09:01:04 +0100
Hi,
I encountered the same problem. Switching back to Boost 1.47.0 solved it. It seems to be a problem between Qt and Boost.
Clément Jamin.
On Thu, Jan 19, 2012 at 8:54 AM, hfang <> wrote:
Thank you very much for your information.
I look out the output of MSVC.
It seems the main problem is this:
6>  :/boost_1_48_0/boost/type_traits/detail/has_binary_operator.hp(50):
Parse error at "BOOST_JOIN"
6>C:\Program Files
(x86)\MSBuild\Microsoft.Cpp\v4.0\Microsoft.CppCommon.targets(151,5): error
MSB6006: “cmd.exe” exit with code 1
Is there any fixing method?
Thanks!
View this message in context: http://cgal-discuss.949826.n4.nabble.com/error-MSB6006-cmd-exe-exit-with-code-1-tp4308902p4309378.html
