[cgal-discuss] Visual Studio 10 - CGAL3.9, boost_1_48_0 64 bit debug produces linking error or unresolved externals
- To: <>
- Subject: [cgal-discuss] Visual Studio 10 - CGAL3.9, boost_1_48_0 64 bit debug produces linking error or unresolved externals
- Date: Thu, 19 Jan 2012 17:14:56 -0000
Hi, I’m having problems linking with boost when building in visual studio 10 – here’s what I’ve done: 1. Download the cgal installer – choose 64 bit install at C:\fresh_cgal\CGAL-3.9> 2. Go to C:\fresh_cgal\CGAL-3.9> and “ cmake -G"Visual Studio 10 Win64" Output is below: 3. Open the solution and build. 4. I now have C:\fresh_cgal\CGAL-3.9\lib\Debug\CGAL-vc100-mt-gd.lib 5. When I link an example, I have lib paths: LIBPATH:"C:\dev\ewan\utils\cgal\install\cgal-3_9_0-WIN64.VC10\lib" /LIBPATH:"C:\dev\ewan\utils\cgal\install\cgal-3_9_0-WIN64.VC10\auxiliary\gmp\lib" And libraries to link "CGAL-vc100-mt-gd.lib" "CGAL_Core-vc100-mt-gd.lib" "libgmp-10.lib" Error comes up: 1>LINK : fatal error LNK1104: cannot open file 'gmp-vc100-mt-gd.lib' Attempts to rename libgmp-10.lib to gmp-vc100-mt-gd.lib result in unresolved externals boost::detail::set_tss_data( ), etc. So I presume the error lies in the version of the gmp lib. What do I need to do to get the correct version – or does the problem lie somewhere else. Any help would be much appreciated, Ewan Otput from cmake: -- Check for working C compiler using: Visual Studio 10 Win64 -- Check for working C compiler using: Visual Studio 10 Win64 -- works -- Detecting C compiler ABI info -- Detecting C compiler ABI info - done -- Check for working CXX compiler using: Visual Studio 10 Win64 -- Check for working CXX compiler using: Visual Studio 10 Win64 -- works -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- Build CGAL from release: CGAL-3.9 -- Packagenames: CGAL-3.9 -- CGAL_MAJOR_VERSION=3 -- CGAL_MINOR_VERSION=9 -- CGAL_BUGFIX_VERSION= -- CGAL_SONAME_VERSION=8 -- CGAL_SOVERSION =8.0.0 -- CGAL_REFERENCE_CACHE_DIR= -- Building static libraries -- Targetting Visual Studio 10 Win64 -- Target build enviroment supports auto-linking -- Using VC10 compiler. -- Generator uses intermediate configuration directory: $(Configuration) -- USING CMake version: 2.8.7 -- System: Windows -- Build type: Release -- USING CXXFLAGS = ' /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHsc /GR -D_CRT_SECURE_NO_ DEPRECATE -D_SCL_SECURE_NO_DEPRECATE -D_CRT_SECURE_NO_WARNINGS -D_SCL_SECURE_NO_ WARNINGS /fp:strict /fp:except- /MD /O2 /Ob2 /D NDEBUG' -- USING LDFLAGS = ' ' -- Found GMP: C:/fresh_cgal/CGAL-3.9/auxiliary/gmp/lib/libgmp-10.lib -- Found MPFR: C:/fresh_cgal/CGAL-3.9/auxiliary/gmp/lib/libmpfr-4.lib -- GMP include: C:/fresh_cgal/CGAL-3.9/auxiliary/gmp/include -- GMP libraries: C:/fresh_cgal/CGAL-3.9/auxiliary/gmp/lib/libgmp-10.lib -- GMP definitions: -- USING GMP_VERSION = '5.0.1' -- MPFR include: C:/fresh_cgal/CGAL-3.9/auxiliary/gmp/include -- MPFR libraries: C:/fresh_cgal/CGAL-3.9/auxiliary/gmp/lib/libmpfr-4.lib -- MPFR definitions: -- USING MPFR_VERSION = '3.0.0' -- Boost version: 1.48.0 -- Found the following Boost libraries: -- thread -- Boost include: C:/v100_libs/Boost/64bit/boost_1_48_0 -- Boost libraries: optimized;C:/v100_libs/Boost/64bit/boost_1_48_0/stage/lib/ libboost_thread-vc100-mt-1_48.lib;debug;C:/v100_libs/Boost/64bit/boost_1_48_0/st age/lib/libboost_thread-vc100-mt-gd-1_48.lib -- Boost definitions: -- USING BOOST_VERSION = '1.48.0' -- Performing Test CGAL_CFG_ARRAY_MEMBER_INITIALIZATION_BUG - Failed -- Performing Test CGAL_CFG_DENORMALS_COMPILE_BUG - Success -- Performing Test CGAL_CFG_FPU_ROUNDING_MODE_UNWINDING_VC_BUG - Failed -- Performing Test CGAL_CFG_IEEE_754_BUG - Success -- Performing Test CGAL_CFG_ISTREAM_INT_BUG - Success -- Performing Test CGAL_CFG_LONGNAME_BUG - Failed -- Performing Test CGAL_CFG_MATCHING_BUG_5 - Success -- Performing Test CGAL_CFG_MATCHING_BUG_6 - Failed -- Performing Test CGAL_CFG_NESTED_CLASS_FRIEND_DECLARATION_BUG - Failed -- Performing Test CGAL_CFG_NO_CPP0X_ARRAY - Success -- Performing Test CGAL_CFG_NO_CPP0X_AUTO - Success -- Performing Test CGAL_CFG_NO_CPP0X_DECLTYPE - Success -- Performing Test CGAL_CFG_NO_CPP0X_DEFAULT_TEMPLATE_ARGUMENTS_FOR_FUNCTION_TEM PLATES - Failed -- Performing Test CGAL_CFG_NO_CPP0X_DELEGATING_CONSTRUCTORS - Failed -- Performing Test CGAL_CFG_NO_CPP0X_DELETED_AND_DEFAULT_FUNCTIONS - Failed -- Performing Test CGAL_CFG_NO_CPP0X_INITIALIZER_LISTS - Failed -- Performing Test CGAL_CFG_NO_CPP0X_ISFINITE - Failed -- Performing Test CGAL_CFG_NO_CPP0X_LAMBDAS - Success -- Performing Test CGAL_CFG_NO_CPP0X_LONG_LONG - Success -- Performing Test CGAL_CFG_NO_CPP0X_RVALUE_REFERENCE - Success -- Performing Test CGAL_CFG_NO_CPP0X_STATIC_ASSERT - Success -- Performing Test CGAL_CFG_NO_CPP0X_TUPLE - Success -- Performing Test CGAL_CFG_NO_CPP0X_VARIADIC_TEMPLATES - Failed -- Performing Test CGAL_CFG_NO_LIMITS - Success -- Performing Test CGAL_CFG_NO_LOGICAL_OPERATORS_ALTERNATIVES - Failed -- Performing Test CGAL_CFG_NO_MESSAGE_PRAGMA_BUG - Success -- Performing Test CGAL_CFG_NO_NEXTAFTER - Failed -- Performing Test CGAL_CFG_NO_STATEMENT_EXPRESSIONS - Failed -- Performing Test CGAL_CFG_NO_STL - Success -- Performing Test CGAL_CFG_NO_TMPL_IN_TMPL_PARAM - Success -- Performing Test CGAL_CFG_NO_TR1_ARRAY - Failed -- Performing Test CGAL_CFG_NO_TR1_TUPLE - Failed -- Performing Test CGAL_CFG_NO_WARNING_CPP_DIRECTIVE_BUG - Failed -- Performing Test CGAL_CFG_NUMERIC_LIMITS_BUG - Success -- Performing Test CGAL_CFG_OUTOFLINE_MEMBER_DEFINITION_BUG - Success -- Performing Test CGAL_CFG_TEMPLATE_IN_DEFAULT_PARAMETER_BUG - Success -- Performing Test CGAL_CFG_TYPENAME_BEFORE_DEFAULT_ARGUMENT_BUG - Success -- Performing Test CGAL_CFG_USING_BASE_MEMBER_BUG_2 - Success -- Library config detected: Core -- Library config detected: ImageIO -- Could NOT find ZLIB (missing: ZLIB_LIBRARY ZLIB_INCLUDE_DIR) -- Found OpenGL: opengl32 -- OpenGL include: -- OpenGL libraries: glu32;opengl32 -- NOTICE: CGAL_ImageIO needs ZLib to read compressed files. That feature will n ot be activated. -- Library config detected: Qt3 -- CGAL_Qt3 needs Qt3, cannot be configured. -- Library config detected: Qt4 -- Looking for Q_WS_X11 -- Looking for Q_WS_X11 - not found. -- Looking for Q_WS_WIN -- Looking for Q_WS_WIN - found -- Looking for Q_WS_QWS -- Looking for Q_WS_QWS - not found. -- Looking for Q_WS_MAC -- Looking for Q_WS_MAC - not found. -- USING QT4_VERSION = '4.8.0' -- OpenGL include: -- OpenGL libraries: glu32;opengl32 -- OpenGL definitions: -- Qt4 include: C:/Qt/4.8.0-WIN64.VC10/include -- Qt4 libraries: optimized;C:/Qt/4.8.0-WIN64.VC10/lib/qtmain.lib;debug;C:/ Qt/4.8.0-WIN64.VC10/lib/qtmaind.lib;optimized;C:/Qt/4.8.0-WIN64.VC10/lib/QtOpenG L4.lib;debug;C:/Qt/4.8.0-WIN64.VC10/lib/QtOpenGLd4.lib;optimized;C:/Qt/4.8.0-WIN 64.VC10/lib/QtGui4.lib;debug;C:/Qt/4.8.0-WIN64.VC10/lib/QtGuid4.lib;optimized;C: /Qt/4.8.0-WIN64.VC10/lib/QtCore4.lib;debug;C:/Qt/4.8.0-WIN64.VC10/lib/QtCored4.l ib -- Qt4 definitions: -DQT_DLL -- moc executable: C:/Qt/4.8.0-WIN64.VC10/bin/moc.exe -- uic executable: C:/Qt/4.8.0-WIN64.VC10/bin/uic.exe -- Library configs detected: CGAL;Core;ImageIO;Qt3;Qt4 -- Configuring done -- Generating done -- Build files have been written to: C:/fresh_cgal/CGAL-3.9 http://www.mve.com/about/people/ewan-brock ***Free commercial licenses for new ASI graduates. *** Midland Valley Exploration Ltd. |
- [cgal-discuss] Visual Studio 10 - CGAL3.9, boost_1_48_0 64 bit debug produces linking error or unresolved externals, Ewan Brock, 01/19/2012
- Re: [cgal-discuss] Visual Studio 10 - CGAL3.9, boost_1_48_0 64 bit debug produces linking error or unresolved externals, Andreas Fabri, 01/19/2012
- Re: [cgal-discuss] Visual Studio 10 - CGAL3.9, boost_1_48_0 64 bit debug produces linking error or unresolved externals, Laurent Rineau (GeometryFactory), 01/20/2012
