cgal-discuss - Re: [cgal-discuss] Visual Studio 10 - CGAL3.9, boost_1_48_0 64 bit debug produces linking error or unresolved externals
  • To:
  • Subject: Re: [cgal-discuss] Visual Studio 10 - CGAL3.9, boost_1_48_0 64 bit debug produces linking error or unresolved externals
  • Date: Thu, 19 Jan 2012 18:41:25 +0100
Hi Ewan,
When you start cmake-gui where you built the CGAL library,
the variable CGAL_AUTO_LINK_GMP should be unmarked.
In previous releases of CGAL we adopted the boost naming
scheme for GMP, but we gave that up again, and precompile
GMP as C library with mingw.
best regards,
andreas
On 19/01/2012 18:14, Ewan Brock wrote:
Hi,
I’m having problems linking with boost when building in visual studio 10
– here’s what I’ve done:
1.Download the cgal installer – choose 64 bit install at
C:\fresh_cgal\CGAL-3.9>
2.Go to C:\fresh_cgal\CGAL-3.9> and “ cmake -G"Visual Studio 10 Win64"
Output is below:
3.Open the solution and build.
4.I now have C:\fresh_cgal\CGAL-3.9\lib\Debug\CGAL-vc100-mt-gd.lib
5.When I link an example, I have lib paths:
LIBPATH:"C:\dev\ewan\utils\cgal\install\cgal-3_9_0-WIN64.VC10\lib"
/LIBPATH:"C:\dev\ewan\utils\cgal\install\cgal-3_9_0-WIN64.VC10\auxiliary\gmp\lib"
And libraries to link "CGAL-vc100-mt-gd.lib" "CGAL_Core-vc100-mt-gd.lib"
"libgmp-10.lib"
Error comes up:
1>LINK : fatal error LNK1104: cannot open file 'gmp-vc100-mt-gd.lib'
Attempts to rename libgmp-10.lib to gmp-vc100-mt-gd.lib result in
unresolved externals boost::detail::set_tss_data( ), etc.
So I presume the error lies in the version of the gmp lib. What do I
need to do to get the correct version – or does the problem lie
somewhere else.
Any help would be much appreciated,
Ewan
Otput from cmake:
-- Check for working C compiler using: Visual Studio 10 Win64
-- Check for working C compiler using: Visual Studio 10 Win64 -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler using: Visual Studio 10 Win64
-- Check for working CXX compiler using: Visual Studio 10 Win64 -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Build CGAL from release: CGAL-3.9
-- Packagenames: CGAL-3.9
-- CGAL_MAJOR_VERSION=3
-- CGAL_MINOR_VERSION=9
-- CGAL_BUGFIX_VERSION=
-- CGAL_SONAME_VERSION=8
-- CGAL_SOVERSION =8.0.0
-- CGAL_REFERENCE_CACHE_DIR=
-- Building static libraries
-- Targetting Visual Studio 10 Win64
-- Target build enviroment supports auto-linking
-- Using VC10 compiler.
-- Generator uses intermediate configuration directory: $(Configuration)
-- USING CMake version: 2.8.7
-- System: Windows
-- Build type: Release
-- USING CXXFLAGS = ' /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHsc /GR
-D_CRT_SECURE_NO_
DEPRECATE -D_SCL_SECURE_NO_DEPRECATE -D_CRT_SECURE_NO_WARNINGS
-D_SCL_SECURE_NO_
WARNINGS /fp:strict /fp:except- /MD /O2 /Ob2 /D NDEBUG'
-- USING LDFLAGS = ' '
-- Found GMP: C:/fresh_cgal/CGAL-3.9/auxiliary/gmp/lib/libgmp-10.lib
-- Found MPFR: C:/fresh_cgal/CGAL-3.9/auxiliary/gmp/lib/libmpfr-4.lib
-- GMP include: C:/fresh_cgal/CGAL-3.9/auxiliary/gmp/include
-- GMP libraries: C:/fresh_cgal/CGAL-3.9/auxiliary/gmp/lib/libgmp-10.lib
-- GMP definitions:
-- USING GMP_VERSION = '5.0.1'
-- MPFR include: C:/fresh_cgal/CGAL-3.9/auxiliary/gmp/include
-- MPFR libraries: C:/fresh_cgal/CGAL-3.9/auxiliary/gmp/lib/libmpfr-4.lib
-- MPFR definitions:
-- USING MPFR_VERSION = '3.0.0'
-- Boost version: 1.48.0
-- Found the following Boost libraries:
-- thread
-- Boost include: C:/v100_libs/Boost/64bit/boost_1_48_0
-- Boost libraries:
optimized;C:/v100_libs/Boost/64bit/boost_1_48_0/stage/lib/
libboost_thread-vc100-mt-1_48.lib;debug;C:/v100_libs/Boost/64bit/boost_1_48_0/st
age/lib/libboost_thread-vc100-mt-gd-1_48.lib
-- Boost definitions:
-- USING BOOST_VERSION = '1.48.0'
-- Performing Test CGAL_CFG_ARRAY_MEMBER_INITIALIZATION_BUG - Failed
-- Performing Test CGAL_CFG_DENORMALS_COMPILE_BUG - Success
-- Performing Test CGAL_CFG_FPU_ROUNDING_MODE_UNWINDING_VC_BUG - Failed
-- Performing Test CGAL_CFG_IEEE_754_BUG - Success
-- Performing Test CGAL_CFG_ISTREAM_INT_BUG - Success
-- Performing Test CGAL_CFG_LONGNAME_BUG - Failed
-- Performing Test CGAL_CFG_MATCHING_BUG_5 - Success
-- Performing Test CGAL_CFG_MATCHING_BUG_6 - Failed
-- Performing Test CGAL_CFG_NESTED_CLASS_FRIEND_DECLARATION_BUG - Failed
-- Performing Test CGAL_CFG_NO_CPP0X_ARRAY - Success
-- Performing Test CGAL_CFG_NO_CPP0X_AUTO - Success
-- Performing Test CGAL_CFG_NO_CPP0X_DECLTYPE - Success
-- Performing Test
CGAL_CFG_NO_CPP0X_DEFAULT_TEMPLATE_ARGUMENTS_FOR_FUNCTION_TEM
PLATES - Failed
-- Performing Test CGAL_CFG_NO_CPP0X_DELEGATING_CONSTRUCTORS - Failed
-- Performing Test CGAL_CFG_NO_CPP0X_DELETED_AND_DEFAULT_FUNCTIONS - Failed
-- Performing Test CGAL_CFG_NO_CPP0X_INITIALIZER_LISTS - Failed
-- Performing Test CGAL_CFG_NO_CPP0X_ISFINITE - Failed
-- Performing Test CGAL_CFG_NO_CPP0X_LAMBDAS - Success
-- Performing Test CGAL_CFG_NO_CPP0X_LONG_LONG - Success
-- Performing Test CGAL_CFG_NO_CPP0X_RVALUE_REFERENCE - Success
-- Performing Test CGAL_CFG_NO_CPP0X_STATIC_ASSERT - Success
-- Performing Test CGAL_CFG_NO_CPP0X_TUPLE - Success
-- Performing Test CGAL_CFG_NO_CPP0X_VARIADIC_TEMPLATES - Failed
-- Performing Test CGAL_CFG_NO_LIMITS - Success
-- Performing Test CGAL_CFG_NO_LOGICAL_OPERATORS_ALTERNATIVES - Failed
-- Performing Test CGAL_CFG_NO_MESSAGE_PRAGMA_BUG - Success
-- Performing Test CGAL_CFG_NO_NEXTAFTER - Failed
-- Performing Test CGAL_CFG_NO_STATEMENT_EXPRESSIONS - Failed
-- Performing Test CGAL_CFG_NO_STL - Success
-- Performing Test CGAL_CFG_NO_TMPL_IN_TMPL_PARAM - Success
-- Performing Test CGAL_CFG_NO_TR1_ARRAY - Failed
-- Performing Test CGAL_CFG_NO_TR1_TUPLE - Failed
-- Performing Test CGAL_CFG_NO_WARNING_CPP_DIRECTIVE_BUG - Failed
-- Performing Test CGAL_CFG_NUMERIC_LIMITS_BUG - Success
-- Performing Test CGAL_CFG_OUTOFLINE_MEMBER_DEFINITION_BUG - Success
-- Performing Test CGAL_CFG_TEMPLATE_IN_DEFAULT_PARAMETER_BUG - Success
-- Performing Test CGAL_CFG_TYPENAME_BEFORE_DEFAULT_ARGUMENT_BUG - Success
-- Performing Test CGAL_CFG_USING_BASE_MEMBER_BUG_2 - Success
-- Library config detected: Core
-- Library config detected: ImageIO
-- Could NOT find ZLIB (missing: ZLIB_LIBRARY ZLIB_INCLUDE_DIR)
-- Found OpenGL: opengl32
-- OpenGL include:
-- OpenGL libraries: glu32;opengl32
-- NOTICE: CGAL_ImageIO needs ZLib to read compressed files. That
feature will n
ot be activated.
-- Library config detected: Qt3
-- CGAL_Qt3 needs Qt3, cannot be configured.
-- Library config detected: Qt4
-- Looking for Q_WS_X11
-- Looking for Q_WS_X11 - not found.
-- Looking for Q_WS_WIN
-- Looking for Q_WS_WIN - found
-- Looking for Q_WS_QWS
-- Looking for Q_WS_QWS - not found.
-- Looking for Q_WS_MAC
-- Looking for Q_WS_MAC - not found.
-- USING QT4_VERSION = '4.8.0'
-- OpenGL include:
-- OpenGL definitions:
-- Qt4 include: C:/Qt/4.8.0-WIN64.VC10/include
-- Qt4 libraries: optimized;C:/Qt/4.8.0-WIN64.VC10/lib/qtmain.lib;debug;C:/
Qt/4.8.0-WIN64.VC10/lib/qtmaind.lib;optimized;C:/Qt/4.8.0-WIN64.VC10/lib/QtOpenG
L4.lib;debug;C:/Qt/4.8.0-WIN64.VC10/lib/QtOpenGLd4.lib;optimized;C:/Qt/4.8.0-WIN
64.VC10/lib/QtGui4.lib;debug;C:/Qt/4.8.0-WIN64.VC10/lib/QtGuid4.lib;optimized;C:
/Qt/4.8.0-WIN64.VC10/lib/QtCore4.lib;debug;C:/Qt/4.8.0-WIN64.VC10/lib/QtCored4.l
ib
-- Qt4 definitions: -DQT_DLL
-- moc executable: C:/Qt/4.8.0-WIN64.VC10/bin/moc.exe
-- uic executable: C:/Qt/4.8.0-WIN64.VC10/bin/uic.exe
-- Library configs detected: CGAL;Core;ImageIO;Qt3;Qt4
-- Configuring done
-- Generating done
-- Build files have been written to: C:/fresh_cgal/CGAL-3.9
http://www.mve.com/about/people/ewan-brock
***Free commercial licenses for new ASI graduates. ***
Midland Valley Exploration Ltd.
144 West George Street
Glasgow G2 2HG
United Kingdom
Tel: +44 (0) 141 332 2681
Fax: +44 (0) 141 332 6792
The structural geology experts
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
