cgal-discuss - Re: [cgal-discuss] Re: Mesh generation question
  • To:
  • Subject: Re: [cgal-discuss] Re: Mesh generation question
  • Date: Thu, 19 Jan 2012 18:13:10 +0100
Le mercredi 18 janvier 2012 12:06:30 Ram a écrit :
> Another problem I see is this: When I use:
> // Mesh criteria (no cell_size set)
> Mesh_criteria criteria(facet_angle=30.0, facet_size=100.0,
> cell_radius_edge=2);
> on a cube polyhedron, I get the attached picture as output:
> http://cgal-discuss.949826.n4.nabble.com/file/n4307908/Capture.JPG
> Why are the triangles not respecting the 30 degree angle bound I put on
> them? How can I fix this? (I want all my triangles to have angles say
> greater than 10 degrees). Is that possible to do? With what mesh criterion?
How has you extracted the output?
Laurent Rineau, PhD
