- To:
- Subject: [cgal-discuss] Re: Mesh generation question
- Date: Thu, 19 Jan 2012 09:30:53 -0800 (PST)
I extracted the output by creating a .vtk file and visualizing it using vtk.
The iterator lines are:
Function: template < class GT, class TDS > void
show_triangulation_edges(std::ofstream &gv, const Triangulation_3<GT,TDS>
&T)
Iterations:
Vertices: for( typename Triangulation_3<GT, TDS>::Finite_vertices_iterator
vit = T.finite_vertices_begin(); vit != T.finite_vertices_end(); ++vit)
Tetrahedrons:
for( typename Triangulation_3<GT, TDS>::Finite_cells_iterator
cit = T.finite_cells_begin(); cit != T.finite_cells_end(); ++cit)
The call to function is done here:
// Triangulation access
MyTriangulation T = c3t3.triangulation();
std::ofstream myfile;
myfile.open("example.vtk");
CGAL::show_triangulation_edges(myfile, T);
myfile.close();
Wired things happen when I visualize the output. One problem is skinny
triangles. The other problem I've seen is when I mesh a cube, some faces
have small triangles, but others have very large triangles.
With some mesh criterion, I do see graded meshes all around.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Mesh-generation-question-tp4300233p4310726.html
- [cgal-discuss] Re: Mesh generation question, (continued)
- [cgal-discuss] Re: Mesh generation question, Ram, 01/17/2012
- Re: [cgal-discuss] Re: Mesh generation question, Laurent Rineau (GeometryFactory), 01/18/2012
- [cgal-discuss] Re: Mesh generation question, Ram, 01/18/2012
- Re: [cgal-discuss] Re: Mesh generation question, Laurent Rineau (GeometryFactory), 01/19/2012
- [cgal-discuss] Re: Mesh generation question, Ram, 01/19/2012
- [cgal-discuss] Re: Mesh generation question, Ram, 01/21/2012
- Re: [cgal-discuss] Re: Mesh generation question, Laurent Rineau (GeometryFactory), 01/23/2012
