Re: [cgal-discuss] Constructing Nef polyhedra from polygons with points at infinity
- To:
- Subject: Re: [cgal-discuss] Constructing Nef polyhedra from polygons with points at infinity
- Date: Thu, 26 Jan 2012 08:18:31 +0100
Did you try defining each polygon as a union of half-spaces?
Sebastien.
On 01/25/2012 03:24 PM, erickee wrote:
Hi,
I have some polygonal regions that include points at infinity, and I would
like to compute their intersection. To do this, I have been trying to
construct Nef polyhedra that describe the regions.
Using the language from manual section 20.3 (link below), my input polygons
involve both standard and non-standard points. (Link:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Nef_2/Chapter_main.html)
Unfortunately, it appears that the Nef polyhedra constructor that accepts
polygons as input requires polygons to use only standard points.
Is there a simple way to construct nef polyhedra from polygons that include
both standard and non-standard points?
Thanks for your help,
-Eric
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Constructing-Nef-polyhedra-from-polygons-with-points-at-infinity-tp4327351p4327351.html
- [cgal-discuss] Constructing Nef polyhedra from polygons with points at infinity, erickee, 01/25/2012
- Re: [cgal-discuss] Constructing Nef polyhedra from polygons with points at infinity, Sebastien Loriot (GeometryFactory), 01/26/2012
- [cgal-discuss] Re: Constructing Nef polyhedra from polygons with points at infinity, erickee, 01/26/2012
- Re: [cgal-discuss] Re: Constructing Nef polyhedra from polygons with points at infinity, Sebastien Loriot (GeometryFactory), 01/27/2012
- [cgal-discuss] Re: Constructing Nef polyhedra from polygons with points at infinity, erickee, 01/27/2012
