Re: [cgal-discuss] Re: Constructing Nef polyhedra from polygons with points at infinity
- To:
- Subject: Re: [cgal-discuss] Re: Constructing Nef polyhedra from polygons with points at infinity
- Date: Fri, 27 Jan 2012 08:18:45 +0100
If you have a patch I can review it and integrate it in CGAL.
Thanks,
Sebastien.
On 01/26/2012 10:56 PM, erickee wrote:
I think that I have solved this problem. In case there's a problem or anyone
else needs this solution... here it is.
Solution first. Here is an example. To create a Nef_polyhedron_2 that
describes the first quadrant:
CGAL::Filtered_extended_homogeneous<int> K;
typedef CGAL::Filtered_extended_homogeneous<int>::Point_2 Point_2;
Point_2 r1[4] = { K.construct_point(Point( 0, 0, 1) ),
K.construct_point( Line( 0, 1, 0) ),
K.construct_point( Line(-1, 1, 0) ),
K.construct_point( Line(-1, 0, 0) )
std::list<std::pair<Point_2*,Point_2*> > polylines;
polylines.push_back(std::make_pair(r1+0, r1+4));
Nef_polyhedron RST(polylines.begin(), polylines.end(),
Nef_polyhedron::POLYGONS);
This code requires that you add an overloaded function to
Filtered_extended_homogeneous.h
At line 1053, there are a few construct_point() functions. Add another:
Point_2 construct_point(const Point_2& p) const
{ return p; }
Here is the code output:
The face of the Nef_polyhedron_2, RST, is:
Edge 1: (0, 0, 1) ---> (1, 0, 0)
Edge 2: (1, 0, 0) ---> (1, 1, 0)
Edge 3: (1, 1, 0) ---> (0, 1, 0)
Edge 4: (0, 1, 0) ---> (0, 0, 1)
This is the first quadrant. This is also the same output that we would get
if we had intersected two half-planes:
(code for this sanity check is below)
There are two other faces that I did not print here and they also match
between the solution and the sanity check.
Why does this work?
-- Nef_polyhedron_2 knows how to construct points at infinity from lines
-- Nef_polyhedron_2 has public functions to construct points at infinity
from lines
-- These construction functions return points of type Point_2
-- We can convert our points at infinity into lines
e.g. infinite point (1,1,0) corresponds to the homogeneous line
(-1,1,0)
-- Therefore we can construct points of type Point_2 for our points at
infinity
-- Nef_polyhedron_2 also has public functions to construct points of type
Point_2 from standard points
-- So we can convert all points, whether standard or non-standard
(infinite) to type Point_2
-- The polygon constructor for Nef_polyhedron_2 is generic and can accept
type Point_2
-- The polygon constructor converts all points into type Point_2, anyway
-- So we convert our points to Point_2 and pass them to the Nef
constructor
Why add something to Nef_polyhedron_2.h?
-- The constructors in Nef_polyhedron_2 use convert all points to type
Point_2
-- This is done by functions named construct_point() (there are 2 or 3
of these)
-- But, we already converted our points to Point_2
-- So we need add another overload of construct_point that constructs
Point_2 into Point_2
-- The function we added does just that:
{ return p; }
-- Line 1053 in Nef_polyhedron_2.h is where the other construct_point
functions are defined.
Code for the sanity check:
typedef CGAL::Gmpz RT;
typedef CGAL::Filtered_extended_homogeneous<int> Extended_kernel;
typedef CGAL::Nef_polyhedron_2<Extended_kernel> Nef_polyhedron;
typedef Nef_polyhedron::Point Point;
typedef Nef_polyhedron::Line Line;
typedef Nef_polyhedron::Direction Direction;
typedef Nef_polyhedron::Explorer Explorer;
// Intersect two half-planes to specify the first quadrant
Line ly(0, 1, 0);
Nef_polyhedron N1(ly,Nef_polyhedron::EXCLUDED);
Line lx(1, 0, 0);
Nef_polyhedron N2(lx,Nef_polyhedron::EXCLUDED);
Nef_polyhedron RST = N1.intersection(N2);
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Constructing-Nef-polyhedra-from-polygons-with-points-at-infinity-tp4327351p4331942.html
- [cgal-discuss] Constructing Nef polyhedra from polygons with points at infinity, erickee, 01/25/2012
- Re: [cgal-discuss] Constructing Nef polyhedra from polygons with points at infinity, Sebastien Loriot (GeometryFactory), 01/26/2012
- [cgal-discuss] Re: Constructing Nef polyhedra from polygons with points at infinity, erickee, 01/26/2012
- Re: [cgal-discuss] Re: Constructing Nef polyhedra from polygons with points at infinity, Sebastien Loriot (GeometryFactory), 01/27/2012
- [cgal-discuss] Re: Constructing Nef polyhedra from polygons with points at infinity, erickee, 01/27/2012
