- To:
- Subject: Re: [cgal-discuss] Re: Mesh generation question
- Date: Thu, 26 Jan 2012 08:15:12 +0100
Did you do it by hand or using a function?
If you did it by hand you should use the non documented function
Your_triangulation_type::vertex_triple_index
Given a Facet F, vertex indices in counterclockwise order are given
by Your_triangulation_type::vertex_triple_index(F.second,i) for i=0..2
Sebastien.
On 01/25/2012 11:22 PM, Ram wrote:
Forgot to attach an example of what I was talking about , here it is:
http://cgal-discuss.949826.n4.nabble.com/file/n4328819/Capture.jpg
The peculiar tetrahedrons/triangles that stand out is what I talk about. Any
fixes for this?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Mesh-generation-question-tp4300233p4328819.html
- [cgal-discuss] Re: Mesh generation question, (continued)
- [cgal-discuss] Re: Mesh generation question, Ram, 01/18/2012
- Re: [cgal-discuss] Re: Mesh generation question, Laurent Rineau (GeometryFactory), 01/18/2012
- Re: [cgal-discuss] Re: Mesh generation question, Laurent Rineau (GeometryFactory), 01/19/2012
- [cgal-discuss] Re: Mesh generation question, Ram, 01/19/2012
- Re: [cgal-discuss] Re: Mesh generation question, Laurent Rineau (GeometryFactory), 01/23/2012
- [cgal-discuss] Re: Mesh generation question, Ram, 01/25/2012
- Re: [cgal-discuss] Re: Mesh generation question, Sebastien Loriot (GeometryFactory), 01/26/2012
- Re: [cgal-discuss] Re: Mesh generation question, Laurent Rineau (GeometryFactory), 01/26/2012
- [cgal-discuss] Re: Mesh generation question, Ram, 01/26/2012
- Re: [cgal-discuss] Re: Mesh generation question, Laurent Rineau (GeometryFactory), 01/27/2012
- [cgal-discuss] Re: Mesh generation question, Ram, 01/28/2012
- [cgal-discuss] Re: Mesh generation question, Ram, 01/21/2012
