cgal-discuss - Re: [cgal-discuss] 3D boolean operation
  • To:
  • Subject: Re: [cgal-discuss] 3D boolean operation
  • Date: Fri, 27 Jan 2012 08:17:12 +0100
I could not open workpiece.nef3 because coordinates used for output are
double.
How do you get the output? if you are using convert_to_polyhedron you
are only getting one shell which can explain why you are missing one
part.
Sebastien.
On 01/27/2012 12:40 AM, noel wrote:
Hi there.
This is my first post and I've only been toying around with CGAL for a few
months now so forgive me if I go about things the wrong way. I'm getting
some strange results with boolean operations. I've uploaded a couple of
nefs for anyone to try out. Upon performing the operation STOCK -
WORKPIECE, it seems to make a mistake of sorts. I'm using the
Exact_predicates_exact_constructions_kernel.
http://dl.dropbox.com/u/3575271/vistii/nef/stock.nef3
http://dl.dropbox.com/u/3575271/vistii/nef/workpiece.nef3
The work piece has the letter A engraved on it. The result of the boolean
operation seems to forget the triangular hole (not the small round one) that
the letter "A" naturally has.
Any feedback will be welcome. Thanks.
http://cgal-discuss.949826.n4.nabble.com/file/n4332193/38.png
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/3D-boolean-operation-tp4332193p4332193.html
