cgal-discuss - Re: [cgal-discuss] external vertexes in a triangulation
  • To:
  • Subject: Re: [cgal-discuss] external vertexes in a triangulation
  • Date: Mon, 30 Jan 2012 15:41:29 +0100
Hi Daniel:
Thank you for your help, but I think that it is not the correct way to solve my problem. When the convex hull is computed not all the external vertexes are included. For this reason, I need other form to know which are the real external vertexes of a triangulation.
Regards and waiting more suggestions
A.
On Mon, Jan 30, 2012 at 3:29 PM, Daniel Duque <> wrote:
On Monday 30 January 2012 15:20:52 Adam Hopkins wrote:
> Hi all,
> Thank you for your previous answers, but I have a last issue related with
> triangulations.
> Using the example code below, I can know which are the external cells of a
> triangulations, but I also need to know which are the external vertex of
> the same triangulation.
I guess you mean the vertices that form the convex hull. Have a look here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2/Chapter_main.html#Subsection_36.4.2
Best,
Daniel
> Is there any form to know which are the external
> facets of each of these cells in order to know which are the most external
> vertexes of this triangulation?
> Concretely, How Can I know which are the external vertices of a
> triangulation?
> std::vector<Cell_handle> infinite_cells;
> T.incident_cells(T.infinite_vertex(), std::back_inserter(infinite_cells));
> for(int ii = 0; ii < (int)infinite_cells.size(); ii++)
> Cell_handle c = infinite_cells[ii];
> Cell_handle e = c->neighbor(c->index(T.infinite_vertex()));
> Regards and thank you for all
> A.
http://dcain.etsin.upm.es/~daniel
