- To:
- Subject: Re: [cgal-discuss] external vertexes in a triangulation
- Date: Mon, 30 Jan 2012 16:18:23 +0100
- Organization: UPM
On Monday 30 January 2012 16:07:18 Adam Hopkins wrote:
> Hi Daniel and Sebastien:
> Again, thank you for your answers. When I say external vertexes, I am
> refering to all vertexes in external faces, is to say: using the example
> code of my first email, I can compute the external cells of a
> triangulation, and each of them has an external face defined for three
> vertexes, which are the external vertexes.
Hi,
That's right: unless I am very wrong, one vertex is the infinite one and the
other two belong to the convex hull...
Best,
Daniel
> For example assume that I have a triangulation of a sphere, I want to know
> which are the vertexes in the external surface. Please, see the code in my
> first email for more references.
> thank in advance and waiting suggestions
> A.
> On Mon, Jan 30, 2012 at 3:58 PM, Sebastien Loriot (GeometryFactory) <
> wrote:
> > What is your definition of external vertices?
> > Sebastien.
> > On 01/30/2012 03:41 PM, Adam Hopkins wrote:
> >> Hi Daniel:
> >> Thank you for your help, but I think that it is not the correct way to
> >> solve my problem. When the convex hull is computed not all the external
> >> vertexes are included. For this reason, I need other form to know which
> >> are the real external vertexes of a triangulation.
> >> Regards and waiting more suggestions
> >> A.
> >> On Mon, Jan 30, 2012 at 3:29 PM, Daniel Duque
> >> <mailto:>>
> >> wrote:
> >> On Monday 30 January 2012 15:20:52 Adam Hopkins wrote:
> >> > Hi all,
> >> > Thank you for your previous answers, but I have a last issue
> >> related with
> >> > triangulations.
> >> > Using the example code below, I can know which are the external
> >> cells of a
> >> > triangulations, but I also need to know which are the external
> >> vertex of
> >> > the same triangulation.
> >> I guess you mean the vertices that form the convex hull. Have a look
> >> here:
> >> http://www.cgal.org/Manual/**latest/doc_html/cgal_manual/**
> >> Triangulation_2/Chapter_main.**html#Subsection_36.4.2<http://www.cgal.or
> >> g/Manual/latest/doc_html/cgal_manual/Triangulation_2/Chapter_main.html#S
> >> ubsection_36.4.2>
> >> Best,
> >> Daniel
> >> > Is there any form to know which are the external
> >> > facets of each of these cells in order to know which are the most
> >> external
> >> > vertexes of this triangulation?
> >> > Concretely, How Can I know which are the external vertices of a
> >> > triangulation?
> >> > std::vector<Cell_handle> infinite_cells;
> >> > T.incident_cells(T.infinite_**vertex(),
> >> std::back_inserter(infinite_**cells));
> >> > for(int ii = 0; ii < (int)infinite_cells.size(); ii++)
> >> > Cell_handle c = infinite_cells[ii];
> >> > Cell_handle e = c->neighbor(c->index(T.**infinite_vertex()));
> >> > Regards and thank you for all
> >> > A.
> >> http://dcain.etsin.upm.es/~**daniel<http://dcain.etsin.upm.es/~daniel
> >> You are currently subscribed to cgal-discuss.
> >> To unsubscribe or access the archives, go to
> >> https://lists-sop.inria.fr/**wws/info/cgal-discuss<https://lists-sop.
> >> inria.fr/wws/info/cgal-discuss>
> > https://lists-sop.inria.fr/**wws/info/cgal-discuss<https://lists-sop.inri
- [cgal-discuss] external vertexes in a triangulation, Adam Hopkins, 01/30/2012
- Re: [cgal-discuss] external vertexes in a triangulation, Daniel Duque, 01/30/2012
- Re: [cgal-discuss] external vertexes in a triangulation, Adam Hopkins, 01/30/2012
- Re: [cgal-discuss] external vertexes in a triangulation, Sebastien Loriot (GeometryFactory), 01/30/2012
- Re: [cgal-discuss] external vertexes in a triangulation, Daniel Duque, 01/31/2012
