[cgal-discuss] Re: How should I implement my own surface simplification algorithm?
- To:
- Subject: [cgal-discuss] Re: How should I implement my own surface simplification algorithm?
- Date: Wed, 1 Feb 2012 18:29:06 -0800 (PST)
Thanks for the reply.
I've read those docs, and now I'm going through the Lindstrom_Turk
implementation code. But the concept I am struggling with is how the costs
for all the vertices are stored, after which the edges with the least cost
are selected and collapsed.
I know that internally a priority queue is used by the Edge_collapse class.
However the thing I can't figure out is, when CGAL tries to GetCost, will
the cost be re-calculated for that edge? What happens after the collapse of
a selected edge? Will the cost will be re-calculated for the edges involved
as well?
There must be something I'm missing, it all just seems so confusing.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/How-should-I-implement-my-own-surface-simplification-algorithm-tp4347083p4350331.html
- [cgal-discuss] How should I implement my own surface simplification algorithm?, freckles, 02/01/2012
- Re: [cgal-discuss] How should I implement my own surface simplification algorithm?, Sebastien Loriot (GeometryFactory), 02/01/2012
- [cgal-discuss] Re: How should I implement my own surface simplification algorithm?, freckles, 02/02/2012
- Re: [cgal-discuss] Re: How should I implement my own surface simplification algorithm?, Sebastien Loriot (GeometryFactory), 02/02/2012
