cgal-discuss - Re: [cgal-discuss] Re: Converting doubles to Filtered_extended_homogeneous
  • To:
  • Subject: Re: [cgal-discuss] Re: Converting doubles to Filtered_extended_homogeneous
  • Date: Fri, 03 Feb 2012 08:42:17 +0100
Sorry I miss your first email.
In Nef you can use points with cartesian coordinates (but you need exact constructions).
Is there a reason preventing you from using
Exact_predicates_exact_constructions_kernel for example?
Sebastien
On 02/03/2012 02:22 AM, erickee wrote:
Update: I have not yet resolved this issue. Furthermore, I have found that
multiplying my homogenous points by a large number causes problems.
If I multiply by 1000, I frequently have overflow issues, even though I am
using ring type long, which I thought would have a sufficient range to work
with my typically small homogeneous points (e.g. [1000 1000 1000]).
On the other hand, if I multiply by only 10, I don't have overflow issues,
but I am throwing away a lot of precision. For example, a homogenous
half-plane [1.0 1.04 1.0] has a 46º orientation, but round(10*[1.0 1.04
1.0]) has a 45º orientation.
I could use a ring type like CGAL::Gmpz, but I haven't figured out how to
convert homogenous Gmpz back to a homogeneous double after my computation is
done. (I need doubles for post-processing in matlab).
I would greatly appreciate any advice on this topic.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Converting-doubles-to-Filtered-extended-homogeneous-tp4332165p4353379.html
