- To:
- Subject: [cgal-discuss] Re: Converting doubles to Filtered_extended_homogeneous
- Date: Fri, 3 Feb 2012 07:27:22 -0800 (PST)
I think this is close, but I still have a conversion issue. The code below
produces a compilation error because it tries to convert to double. How can
I get my points back into a double? I haven't found a conversion
function...
typedef CGAL::Exact_predicates_exact_constructions_kernel::FT FT;
typedef CGAL::Extended_cartesian<FT> Extended_kernel;
typedef CGAL::Nef_polyhedron_2<Extended_kernel> Nef_polyhedron;
typedef Nef_polyhedron::Point Point;
int main() {
Point p(4.2323,4.23);
double hx = p.hx();
std::cout << hx;
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Converting-doubles-to-Filtered-extended-homogeneous-tp4332165p4354895.html
- [cgal-discuss] Re: Converting doubles to Filtered_extended_homogeneous, erickee, 02/03/2012
- Re: [cgal-discuss] Re: Converting doubles to Filtered_extended_homogeneous, Sebastien Loriot (GeometryFactory), 02/03/2012
- Re: [cgal-discuss] Re: Converting doubles to Filtered_extended_homogeneous, Laurent Rineau (GeometryFactory), 02/03/2012
