cgal-discuss - Re: [cgal-discuss] Re: Converting doubles to Filtered_extended_homogeneous
  • To:
  • Subject: Re: [cgal-discuss] Re: Converting doubles to Filtered_extended_homogeneous
  • Date: Fri, 03 Feb 2012 16:38:11 +0100
Le vendredi 03 février 2012 07:27:22 erickee a écrit :
> I think this is close, but I still have a conversion issue. The code below
> produces a compilation error because it tries to convert to double. How can
> I get my points back into a double? I haven't found a conversion
> function...
> typedef CGAL::Exact_predicates_exact_constructions_kernel::FT FT;
> typedef CGAL::Extended_cartesian<FT> Extended_kernel;
> typedef CGAL::Nef_polyhedron_2<Extended_kernel> Nef_polyhedron;
> typedef Nef_polyhedron::Point Point;
> int main() {
> Point p(4.2323,4.23);
> double hx = p.hx();
Write:
double hx = CGAL::to_double(p.hx());
> std::cout << hx;
Laurent Rineau, PhD
