- To:
- Subject: Re: [cgal-discuss] 3D mesh generation and gcc version/optimisation level
- Date: Wed, 8 Feb 2012 19:17:43 +0000
On 8 February 2012 10:43, Laurent Rineau (GeometryFactory)
wrote:
> Le mardi 07 février 2012 12:22:52 Garth Wells a écrit :
>> I've been running into some issues with mesh generation in 3D. I'm creating
>> meshes of rather simple polyhedra (tetrahedra, cubes), but have been
>> finding
>> that the generation randomly fails at times. I'm also seeing a dependency
>> on the gcc version and optimisation level. The code at the end of this
>> message, taken from
>> http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Mesh_3/Chapter_main.h
>> tml#Subsection_50.3.5
>> runs without error with g++ 4.6.1, but with g++ 4.4.6 and the -O2 or -O3
>> flag I get the error
>> terminate called after throwing an instance of
>> 'CGAL::Precondition_exception'
>> what(): CGAL ERROR: precondition violation!
>> Expr: index != Subdomain_index()
>> File: /usr/include/CGAL/Mesh_3/Mesh_complex_3_in_triangulation_3_base.h
>> Line: 160
>> Aborted
>> I've tested with CGAL 3.8 and 3.9. The code is compiled using
>> g++ -O2 -frounding-math test.cpp -lCGAL -lboost_thread -lmpfr -lgmp
>> Any help with this would be greatly appreciated.
> Can you please add:
> #define CGAL_MESH_3_VERBOSE 1
> as the first line of your cpp file, recompile, and give us the output of the
> run, when it fails?
It get:
Inserting protection balls...
insert_corners() done. Nb of points in triangulation: 25
insert_balls_on_edges() done. Nb of points in triangulation: 610
refine_balls() done. Nb of points in triangulation: 616
Start surface scan...end scan. [Bad facets:1202]
Refining Surface...
Legende of the following line: (#vertices,#steps,#facets to
refine,#tets to refine)
(1741,1124,0,0) (328.6 vertices/s)))
Total refining surface time: 3.42021s
Start volume scan...end scan. [Bad tets:2643]
Refining...
(1742,1,0,2642) (250.0 vertices/s)terminate called after throwing an
instance of 'CGAL::Precondition_exception'
Line: 160
Aborted
Garth
> Laurent Rineau, PhD
> R&D Engineer at GeometryFactory http://www.geometryfactory.com/
> Release Manager of the CGAL Project http://www.cgal.org/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
Garth N. Wells
Department of Engineering, University of Cambridge
http://www.eng.cam.ac.uk/~gnw20
- [cgal-discuss] 3D mesh generation and gcc version/optimisation level, Garth Wells, 02/07/2012
- Re: [cgal-discuss] 3D mesh generation and gcc version/optimisation level, Laurent Rineau (GeometryFactory), 02/08/2012
- Re: [cgal-discuss] 3D mesh generation and gcc version/optimisation level, Garth N. Wells, 02/08/2012
- Re: [cgal-discuss] 3D mesh generation and gcc version/optimisation level, Garth N. Wells, 02/13/2012
- Re: Re: [cgal-discuss] 3D mesh generation and gcc version/optimisation level, Laurent Rineau (GeometryFactory), 02/13/2012
- Re: Re: [cgal-discuss] 3D mesh generation and gcc version/optimisation level, Garth N. Wells, 02/13/2012
- Re: Re: Re: [cgal-discuss] 3D mesh generation and gcc version/optimisation level, Laurent Rineau (GeometryFactory), 02/13/2012
- Re: Re: Re: [cgal-discuss] 3D mesh generation and gcc version/optimisation level, Garth N. Wells, 02/13/2012
