- To:
- Subject: Re: Re: [cgal-discuss] Re: merging 3d meshes
- Date: Wed, 8 Feb 2012 10:47:00 -0800 (PST)
Thank you for your help, il will try your solution...
When you said "You said the boundaries of your two polyhedra intersect, but
they do not. ", it was true. Actually, there are several "copeau" files
(approximately 200). For example, i want to make a fuse between copeau.mesh
and copeau1.mesh then make a cut between conteneur.mesh and the result of
the fuse.
Is it still possible?
Best regards,
Arnaud
http://cgal-discuss.949826.n4.nabble.com/file/n4370432/copeau1.off
copeau1.off
http://cgal-discuss.949826.n4.nabble.com/file/n4370432/copeau1.mesh
copeau1.mesh
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/merging-3d-meshes-tp4357251p4370432.html
- [cgal-discuss] merging 3d meshes, arnola79, 02/04/2012
- Re: [cgal-discuss] merging 3d meshes, Sebastien Loriot (GeometryFactory), 02/06/2012
- [cgal-discuss] Re: merging 3d meshes, Arnaud A., 02/06/2012
- Re: [cgal-discuss] Re: merging 3d meshes, Laurent Rineau (GeometryFactory), 02/06/2012
- [cgal-discuss] Re: merging 3d meshes, Arnaud A., 02/08/2012
- Re: [cgal-discuss] Re: merging 3d meshes, Laurent Rineau (GeometryFactory), 02/08/2012
- Re: Re: [cgal-discuss] Re: merging 3d meshes, Laurent Rineau (GeometryFactory), 02/08/2012
- Re: Re: [cgal-discuss] Re: merging 3d meshes, Arnaud A., 02/08/2012
- Re: Re: Re: [cgal-discuss] Re: merging 3d meshes, Laurent Rineau (GeometryFactory), 02/09/2012
- Re: Re: Re: [cgal-discuss] Re: merging 3d meshes, Arnaud A., 02/10/2012
- Re: Re: Re: Re: [cgal-discuss] Re: merging 3d meshes, Laurent Rineau (GeometryFactory), 02/10/2012
